Question about Philips 46PP9302 46" Rear Projection Television
I have a Phillips TV Model No. 46PP93 0217. The
I have a Phillips TV Model No. 46PP93 0217. The TV works fine exect that the picture is very ''fuzzy'', and everything haze a hazy look to it. My Father gave me the TV. He was is a very heavy smoker. I was wondering if maybe it just needs a good cleaning?
  • Philips Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
I have a Phillips TV Model No. 46PP93 0217.  The - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 30, 2010
Testimonial: "after looking at the pics on the link at the bottom I think this maybe my problem (convergence) I will give it a try. How do I install the convegence kit will probaly be my next question. And by the way, thanks"
Phillips 409fl7505d/f7
I once had a problem with a Phillips tv.It was less than one year old and one day ,all of a suddenm a black screen came up.I elarned it was called the "black screen of death" and that other people had gone through the same thing.Someone online had actually written to Phillips and they had gotten a new TV form them,so I tried the same thing and amazingly,Phillips gave us a new TV and came and took the old one.The enw worked fine. So you may have a lemon on your hands.Unfortunately, I do not have the letter I sent to them but the replacement they sent me was part of their "Rapid Replacement" program.This wa sin 2008 so I'm not sure if they still ahve it but it may be worth a try.
Apr 09, 2013 | Philips 40PFL3705D 40 in LCD TV
I have a 52 or 55 inch phillips magnavox ptv 805 rear projection tv but the color isnt right on it everything else works fine i can see the picture fine but its just the color what can i do
Thats a common problem caused by the CRT coolant needing replacement. The Phillips CRT coolant kit is available from www.tvrepairworld.com which contains the coolant and the CD with instructions.
Jun 30, 2011 | Televison & Video
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
Sony Bravia model #KDL52WL130 worked fine for first year then picture went very dark for the 1st 30 minutes it was on but eventually cleared up. Now it takes longer and screen is completely blank. Sound...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years, some sooner, because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No picture on crt tv
This problem is related to video IC that is mounted on c board, mostly it poped and needs replacement. I don't know the model no as you didn;t given so can't tell you the exect ic number. Check it on the base unit of the tv and you will find it. Just replace it along with resistances in surrounding and your tv work fine again.
Thanks for using fixya.
Nov 18, 2009 | Televison & Video
My Phillips Tv keeps turning itself off after around a minute,the power button remians on and green but no picture or sound. It is like the fuse keeps tripping. If you unplug the tv and switch it back on...
The main power supply is trying to fail. You might try giving us the model number since we can't guess exactly what kind of TV you have; LCD or plasma?? They suffer from some differing ills-
Oct 23, 2009 | Philips Televison & Video
I have a phillips model # 60pw9383-17f tv.sounds
Sound with no picture on this model is typically the HVG/Flyback.
Sep 04, 2009 | Philips 60PW9383 60" Rear Projection...
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Philips 46PP9302 46" Rear Projection Television Logo
880 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
