Question about Kenmore 54599 / 54592 / 54594 / 54596 Side by Side Refrigerator
Divider between fride and freezer hot to touch on my kenmore 50592003
  • berli21 May 30, 2010
    When I started the fan it appeared to be working fine and started spinning. Does that mean it is fine or should I check the connections.
    I recently cleaned the coils and they appear fine.
    Scholar:
  • 59 Answers
Some heat in that part is normal but there are 2 things that can cause that section to become very hot.
The condenser fan may not be operating and is located right beside the compressor and I believe yours will be in the back behind the lower access panel. If the compressor is operating the fan should be as well. If the fan is not operating you might try to give it a spin with a screwdriver to see if it appears weak. If it does not try to operate then you are going to have to test it for power.
The second thing is the coils that fan pulls air through has become blocked or dirty.
I hope this helps.
Posted on May 29, 2010
  • Gene c May 30, 2010
    Most always what that means is you need to replace the fan. Please do not leave it that way as this fan is what helps cool the compressor. If you do not replace it this could lead to compressor failure.
    Thanks.
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
Kenmore elite side by side w/ middle divider super hot
absolutely not
that middle peice should be hot to the touch
this is the mullion heater or yoda loop in the old days
this is what controls moisture from entering the unit
when you open the dooor
mine has been running for 7 years no worries
Oct 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
The divider between the freezer and refrig is very hot to touch.
Normal for that strip to be warm since the cooling system is routed right behind it for heat transfer and to eliminate condensation. Will be warmer with increase in room temp, but if it is a significant change you should inspect/clean the coils behind the panel in the rear of the unit.
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer and refrigerator are not cold enough.
you problem check and see if your fan condeser working best call service
Mar 22, 2009 | Kenmore 53092 / 53094 Side by Side...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Service light is blinking & rubber trim is hot
usually when the center divider is hot to the touch, it means that the compressor is running hot. either your compressor fan is not running or it is stuck or running too slow. Joe
Nov 19, 2008 | Sub-Zero 680 / S
Hot compressor
its defrosting. from what i can make out you have a system fault it struggles to pump gas. hope this helps
Feb 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 54599 / 54592 / 54594 / 54596 Side by Side Refrigerator Logo
115 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
