Question about Briggs & Stratton Garden
Yardman intek 12A-979L401 runs with white smoke and stops, the ohv valve cover is full of a oil and gass mixture, the oil fill has the smell of gas in it
    President:
  • Briggs & Str... Master
  • 1,545 Answers
The carburetor has probably malfunctioned and the needle valve is staying open. It is responsible for most of your problems. Oil will HAVE to be changed, Don't run it till fixed. Pull carb, disassemble and clean noting condition of internal parts. Install rebuild kit if possible. The white smoke is a result of either water in the gas or gas in the oil....or a combination of both.
Posted on Jun 13, 2010
Cranks but sputters, blows grayish/white smoke, and I do smell gas in the oil. What could cause this?the blades it cuts off.
do not run or try until you change the oil . sometimes the float sticks in the carb and fills the crankcase with gas . I like to add an inline shutoff valve .
Aug 28, 2016 | Garden
It has white smoke when u run it for 10 min it stops
Sounds like a bad head gasket. Check your oil after car sat all night. See if there is white , or any signs of water in your oil. Smell dipstick at the same time to see if there is the smell of gas in the oil. While car is cold check the coolant for traces of oil in the cooling system. , or the smell of gas present. When the head gasket goes,it no longer separates the different ports for oil, coolant, and gas mixtures. What happens is that coolant gets into your engine cylinders where gas, oil, and air mix, and ignite. This causes steam to come out of the tail pipe. If you are going to change it yourself, keep me informed and I can walk you through it. What size motor is in the car?
Jan 11, 2013 | 1994 Ford Thunderbird
Briggs & stratton intek 17.5hp smoking
check the oil see if it smells like gas if so the carb is not sealing over filling and draining into the oil a new carb can go bad or ts gas from the bad old one
Sep 20, 2012 | Yard Machines Garden
White smoke
smell the oil and see if it smells like gas the needle valves don't seat and gas overflows into the crankcase if so change the needle and seat and change the oil run it without a load and the change the oil a second time
May 11, 2012 | Briggs Stratton IC Horizontal OHV Engine ...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
13.5 OHV B&S won't stay running, blows gas out carb.
Check to see if the oil is over filled. check if the oil smells like gas, could be a gas leak into the crank case.
More than likely the head gasket is blown internally, causing excessive crank case pressure
Aug 15, 2009 | Parks Optical 13.5hp Briggs And Stratton...
I see a lot of white smoke out of the outlet, what can be the problem i have a 15.5 hp intek ohv motor
1) CHECK THE OIL LEVEL IF IT IS OVER FULL REMOVE SOME OIL TO THE FULL MARK
2) IF YOU MOW ON HILL KEEP THE CARB ON THE DOWN SIDE OF THE HILL
3) WORST CASE RINGS OR VALVE SEALS
Jul 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22hp Briggs problem. Loading up, runs
Try checking the prefilter on your air filter. I had a similer problem and mine prefilter was completly covered in dirt. I changed the air filter and it solved my problem. Also make sure the air intakes are not partially clogged with dirt or other stuff.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
324 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
