Question about Maytag EPIC MFW9700S Front Load Washer
F09 f h code flashing first replaced water valve (6 weeks ago) worked but came back now put in new flow meter and pressure valve and no diferance... also put in line water filter ( we have hard water and scale ) only way to do a loundry is to press off and start about 6 times over the cycle.. help!!! some times i will get f 09 too....
  • 10,515 Answers
This is a Tough Call, if you have already Replaced Flow Meter and Pressure Call.
Along with F09, more likely it indicates a Faulty Circuit Board or CCU Unit. At this Moment, i could only suggest you a Repairman to take care of it as both the parts are expensive and there is no way to get 100% Guarantee that which one of them is at fault.
This is the Complete Detail for Code F H :-
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 29, 2010
  • Roman Leszczynski May 29, 2010
    i pretty much did all of you ideas ...will air in water pipes couse a problem and if yes how do you fix it... and is their some thing like 'clearing the codes" of the machine?
  • taran_2005
    taran_2005 May 29, 2010
    Thanks for your response!!l
    The Only way to get the Codes Reset is to Unplug the Machine for Few Minutes, say 30 Minutes. There is no other way to reset the Codes until you replace the Faulty Component.
    Air in the Pipe could cause a Problem but i have never seen F09 code along with FH.However,Make sure that the drain hose is not stuck way down the stand pipe.
    Make sure that the top of the stand pipe is not taped shut so that it is
    air tight. A problem with proper drain hose installation could cause a
    siphoning problem and may result in this fault code.
    Hope i helped you.
    Thanks
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
Fh code when filling but it has water coming into the machine
see this causes and fix it. God bless you
FH No water detected entering machine or pressure switch trip not detected If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Possible Causes / Procedure
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.
Oct 11, 2012 | Washing Machines
On Duet Front Loader- Error code F/H. Can see plenty of water coming in so I suspect pressure switch. Is this a common problem? I don't quite understand your pressure switch check procedure in your...
This error code F/H tells that no water entering the machine is detected during the fill step of the wash cycle. It can be due to siphoning, pressure switch not tripping or stuck in the empty position, or the water flow meter is not reading the correct water flow. Make sure that no water is draining out of the drain hose due to siphoning as water fills in and position the end of the hose to prevent such condition.
The pressure switch is stuck and not tripping if after 8 minutes the water flow meter has detected 10.5 gallons of water passing through it but the control has not detected the pressure switch trips. The water valves are then turned off and the error code is flashed. The error code is also flashed if after 30 seconds the water valves are turned on and no water is detected entering the machine due to sticking flow meter pinwheel or the flow meter is not positioned properly.
The flow meter is position sensitive. The pinwheel must be installed vertically. Any canter to it may cause the wheel to stick. Many times the F/H error code pops up only when HOT water passes through the flow meter. The hot water may be softening the hoses on either side of the meter, causing the flow meter to canter. Stuck or cantered pinwheel affects the flow meter's ability to read water flow accurately. Disconnect the hoses from the flow meter then blow air into the inlet to free a possible stuck pinwheel. Replace the flow meter if the pinwheel is totally stuck and cannot be freed.
Check the pressure hose for possible kinks or air leaks if the flow meter pinwheel is positioned vertically and turning freely. Kinks and air leaks in the pressure hose prevents pressure built up in the pressure switch dome and the pressure switch cannot trip. Check the pressure hose including its connections to the pressure switch and the bottom of the tub. Blow air into the pressure hose to clear possible clogs or kinks and check it for air leaks. Also blow air into the pressure switch dome to free a possible pressure switch contacts welded or stuck in the empty position. You should hear the pressure switch clicks if it is tripping. Replace the pressure switch if not tripping and the pressure hose has no kinks or air leaks.
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore frontload, model 110.45872-400. water pump has been leaking ordered pump and replaced it myself. It seemed easy. plugged back in. Hook water supply back. turned on. It started like it was...
OR
Oct 15, 2009 | Washing Machines
Washer stops and flashes H and F
OR
Replace failed component.(likely the pressure switch or hose)
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine starts beeping and flashing H F???
OR
Oct 04, 2009 | Whirlpool Washing Machines
What do these error codes mean?
FH
OR
Replace failed component.(usually this will be failed pressure switch. the hose should be replaced as well)
Jul 20, 2009 | Kenmore Elite 45986 Front Load Washer
Standing water, won't spend...code F
F/H No water detected entering machine or Pressure switch trip not detected.
Or
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fh error
Not familiar with your model, re flow meter, but.....
If after 30 seconds the control does not detect water entering machine the valves will be turned off and the error code will be displayed.
Or
Press "pause + cancel" twice to clear the display.
1. Make sure that both valves at the water source are turned on full.
2. Check for plugged or kinked inlet hoses or blocked screens in the inlet valves
3. Verify inlet valve operation if there is water in the unit:
4 Verify Drain pump operation
5. Pressure Switch Hose is in good condition and properly
connected to tub & pressure switch (which is below the
control unit)
6.Verify there is not a siphon problem
7 Verify wire harness connections to:Inlet Valves, Pressure
(CCU)
Nov 28, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite 4t
This what to check for F/H code from repair manual.
If the water is coming into machine, make sure drain hose is only sticking into drain pipe about 6 inches. Post back if you have any questions.
Or
Potential Causes
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Nov 07, 2007 | Kenmore Elite HE4 Electric Dryer
Maytag EPIC MFW9700S Front Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
