Question about Whirlpool GI15NDXTSS
Water cooler problem
I have a Whirlpool water cooler which is about 4 years old and although both the hot and cold temp. settings work fine after about 1 hour of having the temp. set on coldest setting and blue light on and not flashing the light starts to flash as if the water is not cold yet. this has been a problem since day 1. Although it does not affect the water at all is the light supposed to start blinking? I can switch the cold off and punch the button three times to select coldest setting again and light will stay on solid for about another hour then repeat the blinking. Would like to know if there is anything I might do to fix this Glich. Thank you for any help you might be able to give me on this matter. Bill Hartle
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can get started then okay
Posted on Jan 29, 2013
2 Suggested Answers
SOURCE: Water freezes solid
Had a tech in .
Posted on Dec 04, 2009
F&P smartdrive washing machine 4 years old works fine but want the warm water hotter as it is to cold. can i adjust it?
run hot water b4 turning on machine temp are set by electronics can be adjusted slightly for just certain cycles will not make much different turn your water heater up 20 degree its what you want
Jun 27, 2016 | Washing Machines
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Aug 27, 2012 | Refrigerators
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Bought a hot water heater made by whirlpool for 2 weeks only had enough hot water to fill 1/4 of the tub then the water turned cold . They have replaced the hot water heater and still has same problem....
The down tube in the tank has fallen off or the hot and cold lines are reversed at the tank. I'm going to assume it is gas , if its electric you need to test the heating elements for continuity and temp settings. as well as the down tube in the top of the tank that sends the cold water feed to the bottom of the tank..
Mar 13, 2011 | Whirlpool Home
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Low hot water pressure
it sounds like you need to up the temp on your water heater so that you are mixing more cold with the hot .be careful hot water can cause burns if valve is 4 years old then it has a limit stop do not set above 120 *you will need allen key and thermometer to check temp
May 05, 2009 | Moen Plumbing
Temperature Control Problem
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
Aug 06, 2008 | Whirlpool WTW5500S
Whirlpool GI15NDXTSS Logo
885 people viewed this question
Top Whirlpool Kitchen Appliances - Others Experts
richie46
John Tripp
John Tripp
Are you a Whirlpool Kitchen Appliances - Other Expert? Answer questions, earn points and help others
