Question about Dell LA65NS000 AC Adapter
I need a service manual to repair a dell ac
I need a service manual to repair a fa65nso-00 Dell ac adapter. The green led that shows DC power (19.5V) is being fed to the output NO MORE LIGHTS and I could only TEMPORARILY make it light and find the DC current at the output, but the problem remains...I believe it to be a bad contact. I live in a small 7,000 inhabitant city in Goias State, Brazil, 230 Km North of Brasilia and there is no Dell Technical Assistance here.
  • yadayada
    yadayada May 29, 2010
    they don't make service manuals to repair these, they are throw away items. they are cheap on ebay.
SOURCE: No Picture
Has anyone managed to find a solution to this problem?
Posted on May 08, 2008
  • 3 Answers
SOURCE: Dell Inspiron 1501 AC Adapter error message
The Dell 1501 ac adapter (possibly other Dell’s as well) has been known to be problematic because of its lack of a plug to jack secure fit. You will notice that the plug can all too easily be pulled from the jack, as opposed to other systems where the plug fits more securely onto the jack. The plug and jack combination is poorly designed so that over time, the plug will come unseated depending on how much movement the machine is subjected to. This will result in power error messages or outright power-up failure. So before assuming you have a faulty adapter, make sure that it is not just a loose plug that is causing the problem. If you look inside the jack, you will notice that there is a 3mm region of non-conductive material nearest the surface of the jack. Use a strip of standard electrical tape 3mm wide and long enough and wrap it around the base of the plug (you may need more than one layer of tape to get a good fit). I have used this method to secure my plug and it has served me well. If the tape comes undone over time, just simply replace it. A more “elegant” method would be to use an “O” ring of the appropriate size (about 6mm) around the base of the plug in lieu of the tape.
Posted on Dec 25, 2008
  • 479 Answers
SOURCE: Dell Latitude D430 laptop. Laptop
the issue seems with the inverter board of the machine and chek once the machine at any other place.
Posted on Jan 29, 2009
benwabnick
  • 2404 Answers
SOURCE: I have a Dell D600 (PP05L), its not powering up no
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
Posted on May 04, 2009
ajx13
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
My laptop is not powering on help
1.Connect the Ac adapter to a known good power outlet. Check the Power LED indicator on AC adapter (without plugging into the Notebook). We are only checking the power AC adapter to see if that is working.
2.If LED on the AC adapter is not lit (when unplugged from notebook), reseat the AC adapter brick and cable. If still there is no light on AC Adapter replace AC adapter and Power cord.
3.If LED on the AC Adapter goes off only after connecting to Notebook, the issue is with the motherboard. Replace Motherboard, DC-In port (AC adapter connector).
4.If the AC Adapter LED is always ON, take a technician's help and reseat the Power Button Board. You can refer to the Service Manual for details on how to reseat the Power Button Board. (NOTE: Before the notebook chassis is opened ensure all the power connections including battery and external devices are disconnected)
Jun 07, 2014 | Dell Inspiron Laptop 1440
Electrical circut of pa-1650-05D
Try Ebay they have all kind of power supply for laptop, I found a replacement for most of the one I seek for.
Jan 04, 2014 | Dell Part Number PA165005D PA165005D2...
What are the Schamatics to a Dell ac/dc adapter MODEL: DA90PS1-00
Specification of DA90PS1-00 AC Adapter:
Output: DC19.5V 4.62A
Power: 90W MaxOutlet: 3-Prong
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin
Sep 18, 2011 | Dell Laptop DC Power Jack (DELLDL271600)...
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
Dell d600 will not power up. When connected to AC power the green led will go out. Is this a jack problem or a internal supply or what???
well, if you try more than one wall outlet and you have that issue, it is possible that you may have a bad plug. you can always buy a power supply at radio shack or best buy. and test it. or the best solution is go to a local computer repair shop, i'm sure they have plugs to try and see if it powers up.
Oct 17, 2009 | Dell Latitude D600 Notebook
My Dell Inspiron laptop won't power up. There are no lights AT ALL. It worked when I left for holiday. I have bought a new AC/DC power unit: just the same. The green light comes on when I plug the AC/DC...
If the light on the A/C adapter "goes out" when you connect it to the Laptop... then your motherboard is bad.
Your motherboard is "shorting out" the A/C adapter, in which case you will need a new motherboard.
Sorry....
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Bad motherboard for M1730
With the Dell laptops, if it were a broken power jack you would know by looking. It would show signs of missing/broken solder around the solder points. You could do a continuity test with a Volt/Ohm meter. However this would be tough with the barrel plug dell uses.
Now as far as getting someone to repair it for you. Iwould recommend a guy I use in florida. I originally found out about him on Ebay, he does a great job repairing motherboard issue (on the component level). He has ALL the proper equipment to ddo this. I have provided a link to his Ebay contact page. Send him an email, I am sure he can fix ya up.
May 19, 2009 | Dell Inspiron XPS M1730 (N09X7304) PC...
DC Adapter for laptop doesn't work
there is nothing you can do appart from replace the car adaptor or check that the cigarette lighter is recieving power to the socket
regards
Nov 24, 2008 | Dell Inspiron 6000 Notebook
Dell LA65NS000 AC Adapter Logo
337 people viewed this question
Alun Cox
