Question about Sony RDR-VX500 DVD Recorder/VCR
Can't play finalized DVDs dubbed from VHS on other Sony DVD players or PC
I just dubbed from VHS to DVD (Memorex DVD+R) for the first time. On the first 3 I forgot to finalize so I put the DVD back in and finalized. On the 4th I remembered to finalize when the VHS stopped.
All of these play OK on the same machine but will not play on another SONY DVD player or on my Dell Inspiron. The tapes used were of various ages.
Please help!
  • 1 more comment
  • Anonymous Apr 08, 2008
    Well, when I try to finalize again, the disc settings option is grayed out.
    Since we talked I've had a little success. (1) Two of my dvds WILL play on the others.
    (2) One won't play -- it says "loading" for a long time, then something about a disc error. I'm wondering if there wasn't enough space left to finalize - it was the longest running one I did. I'll try again and stop in before the end.
    (3) The last two are a mystery. They are both very short. After I finalized and put them back in the SAME player (vx500), the disc was damaged. It wouldn't load, and kept going to stop. One of these was from a VHS that was recorded in EP mode. I don't know about the other one since it was given to me.
    Thanks for your help!
  • Joseph Lathem
    Joseph Lathem Dec 16, 2011
    As a general rule, if you can't load it in a PC drive, the disc is corrupt. Your best luck is to try to record it again.
    Also DVD-Rs tend to work a bit better than +Rs on most DVD recorders for some reason.
    (Would have posted as a solution, but the solution box is missing on this page...)
    President:
  • 1,950 Answers
It sounds like the disc were not finalized properly. Are you sure the player finalized the discs?
Posted on Apr 08, 2008
  • Damen Wong
    Damen Wong Apr 08, 2008
    What happens when you try this disc on the other DVD player and on the PC?
SOURCE:
Recorded a movie on the DVR, played it & recorded it onto a Sony DVD-R with the Sony RDR-VX525, I believe it finalized & did everything it should. However, it won't play. It says disk error. I went...
what happened was that you probably chose a disc speed on the DVD that was too fast or slow for the dvd players that you are putting it in to. Try re recording it but when under the DVD section, on your remote, choose REC Mode till it says SP. That one should work on just about any dvd player. I had the same problem with mine. Here is a step by step instruction on how to dub from VHS to DVD correctly. If you follow all the steps, you should be fine :) http://angrytechblog.com/2011/02/how-to-one-touch-dub-vhs-to-dvd-on-the-sony-rdr-vx525/
Jan 20, 2011 | Sony RDR-VX525 DVD Recorder/VCR
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
DVD does not play on other players or computer
Hi and welcome to FixYa,
Your description indicates that the last step in the DVD recording has not been performed on these discs that were recorded on the Magnavox. This would be "finalize" or instruct the Magnavox that no other files would be written/recorded on the current disc. Thereafter, the Magnavox would complete the DVD disc making it playable in any other player. Normally, finalization would take a bit of time to complete.
Pls post back how things turned up. Good luck and thank you for using FixYa.
Feb 02, 2009 | Philips Magnavox DVD/VCR Dual Player
I Have been trying to dubb VHS tapes to DVD''s. They record alright, but then when I go to play them on another DVD player they won't play...how do I get them to finalize? I have went through the menu and...
--- for some reason this unit does not finalize automatcally.
--- the instructions for finallizing are on page 52 of the owners manual.
--- they are as follows:
1) Press Setup
2) Scroll down, select "Disc Edit", press "OK"
3) Scroll down, select "Finalize", press "OK"
4) Select "Yes", press "OK"
Finalizing will start.
--- have done this operation several times, works Ok.
Joe
Jan 05, 2009 | Philips Magnavox DVD/VCR Dual Player
FINALIZING DVD+R DUBBED FROM VHS TAPES
The manual gives you incorrect info.
To FINALIZE disk:
1. Press [HOME] button;
2. select [SETUP].
3. Scroll down to DVD ICON and SELECT
4. Select [FINALIZE]
Perfect Answer provided by "petoNOVY" - THIS ANSWER ALSO APPLIES TO ZENITH XBR616 - I struggled for 2 years to find it!!! THANKS!!!
Dec 17, 2008 | Zenith XBR716
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
Apr 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
VHS TO DVD DUB ERROR ON PLAYBACK
Sounds like the DVD is not finalizing or not doing so properly. Check your setup options...
Mar 30, 2008 | Sony RDR-VX555
Panasonic recorded dvds? what's up?
http://service.us.panasonic.com/OperMan/findmanual.aspx?model=DMRES40V
Try the Manual. It has a finalizing section. This is the link above.. Pat
Aug 02, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Sony RDR-VX500 DVD Recorder/VCR Logo
489 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
