Question about Boating
Boat won't start. Starter doesn't engage, just buzzes. Chevy inboard motor with Volvo outdrive. Any way to confirm it is the starter?
    Top Expert:
  • Boating Master
  • 51,092 Answers
It may just be the starter soleniod . much cheaper fix than the starter
Posted on May 30, 2010
Intermittent starter won't engage on mercrusier7.4 1988 boat engine
might be a burned spot on the starter contacts where the brushes power the motor.
tap the starter to see if problem goes away.
sometimes you can clean the contacts but that is a temporary fix.
Mar 11, 2013 | Cars & Trucks
Omc 3.0 motor fires but will not start
Yes, the ignition switch or ignition wires on the Run side of the switch may be bad. Most people don't know that the Start side of the switch can power the spark plugs. But when you stop cranking and let the key go to Run you can lose the spark to the plugs
There is also a safety feature in the OMC system. The micro switches on the linkage have to be adjusted or timed. This is so the throttle is not set too high to engage the outdrive. So it does a lockout of the module or a lockout of the starter.
A second feature prevents starting if the outdrive is up too high. This prevents breaking Ujoints and dangerous planing conditions from an improperly trimmed outdrive. Lower the outdrive.
You will see the microswitches, see if the linkage can be moved to line up the contacts. They are simply contact switches and you may have to temporarily disconnect some linkage to test start.
Apr 24, 2010 | Boating
1989 galaxie boat. inboard/outboard 4.3l stiff steering
The first thing I would do is disconnect the steering at the transom. You want to find out if the problem is in the helm(steering wheel) or in the inboard/outboard pivots.
When you turn the wheel after the disconnect, it should not be hard. There is a set screw in the steering assembly either above or below the dash. There should be enough tension so the boat does not wander but not enough to be terrible to steer.
Next go to the outdrive. Without the steering connected, the outdrive should move with minimum resisitance in either direction. There are pivot points on top and bottom that should have marine grease at the start of each season.
You have a 21 year old boat. The driveshaft in the Inboard/Outboard should be greased every 2 to 3 seasons and the watertight bellows can be inspected at that time.
Now if the steering is even worse under power, you need to adjust the fin that drops down behind the prop. This part controls Torque steer so the outdrive is not trying to turn on you and wants to stay straight. If you do not have a problem leave it alone.
You can get an estimate for the driveshaft service and greasing U-joints and inspecting the bellows. They should grease the pivot points then too. I am told its about a 2 hour job. In my area its 60-70 an hour.
Apr 12, 2010 | Boating
Looking for location of impeller on a inboard motor boat?
If it has a OMC or Volvo most are in the top of the outdrive. If your motor looks like a car engine it can be if the front just like a car. This website claims they have online access to repair manuals so I would look there first. Go to other websites and look for impellers with the brand of motor, like Volvo impellers, Mercruiser impellers and some of those sites have excellent parts diagrams.
Apr 24, 2009 | Boating
5.8 cobra will not turnover starter has been tested
There are lockouts in the outdrives. You need to have the outdrive down for the starter to work. There is an operating range on the outdrive to keep the driveshaft from breaking. Be sure to have vent blowers on and water to outdrive or in lake. You don't want to burn up the impeller. Also you need discharge water in exhaust passages or it will destroy rubber parts.
Mar 26, 2009 | Boating
Volvo penta boat manual
Thank, but I have managed to get manual on engine
Aug 20, 2008 | Boating
Boating Logo
182 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
