Question about Goldstar Heating & Cooling
I just sent a question and then lost my internet connection. I am repeating the question briefly. I have a Goldstar window air conditioner, model R5050. It was in the home when I moved in. Any idea how old it is? Does it require any change of filter or repletion of coolant? If so, are these things available and how do I do it? Unit does not adequately cool the room. The room is a third floor (top floor) bedroom of a very tall home and it is 345 square feet with a 9 foot high ceiling. Thank you. Maureen O'Halloran, Newton MA mohalloran@rscj.org
    President:
  • 949 Answers
If you can send the serial number I can try and estimate the age.
The unit does not require replenishment of the coolant unless there is a leak in the sealed system part of the unit.
The maintenance on the unit is to clean the filter which is located just behind the front grill. It will slide in between the front panel and coils that look like a radiator in front.
Every couple of years it should be washed. It should be done from the outside, you can look in the side louvers from the outside and look at the coils in the back, if they are dusty or dirty, you can spray them with a hose from the outside in.
Other than that there is no maintenance, if cooling is not adequate from that point some would need to look at it from a repair standpoint.
Posted on May 29, 2010
I've had my air conditioner for a few years now and it no longer cools anything. The fan works, the condenser(?) turns on when I set it to cool instead of fan, but the air coming out of it isn't...
You need to determine if the compressor is running, if it is and you have no cooling then you either have lost charge or bad compressor, these units re not worth replacement compressor
Jun 22, 2011 | Goldstar R5208 Air Conditioner
My air conditionner is not working properly. It sends cool aire keep getting code E3 What can I do to fix it Tks
micheline, according to the LG Owner's Manual for the Model Number you listed, there is no LED display on the casement window unit (please see the Owner's Manual link below). How are you getting an E3 error code? Or by chance, did you list the wrong model number? Even Goldstar, that is made by LG, doesn't show your model number.
Please advise. Thanks.
Jun 01, 2011 | Goldstar LG LC1200 Casement Air...
Where is the drain plug on this unit goldstar 6500 airconditione
There is no drain plug,if it is not draining,then the drain holes are stopped up with trash and debris,remove the unit from the window,and take it out side,use a water hose to clean it out,and you will be fine,if this was at all helpful,please rate,thank you.
Jul 05, 2010 | Goldstar KG6000R Window Air Conditioner
Bought goldstar portable air conditioner model #gp100ce.did not get manul with how can i get one ..tanks
search for Goldstar on internet. They may have manuals available free download.
Aug 20, 2009 | Heating & Cooling
GoldStar model GWHD5000
Make sure that the unit is properly mounted in the opening (I take it it's in a window) and that it is level or at least not tipping inward as in the outside being higher than the inside. If unsure about how to mount it properly, consult your owners manual. Your installation should be reasonably close to the illustrations.
Jul 13, 2009 | LG Goldstar GWHD5000 wall/window Air...
Goldstar 10000 blows water out front
Two possible problems.
1. High humidity in the space being cooled
2. Drain line that runs from the front (where the water is blowing out) to the back where it is sent to evaporate. Clean out the drain line and condensate pan under the fins where the water is blowing out.
Jul 10, 2009 | LG Goldstar GWHD5000 wall/window Air...
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Installing
Turn the curtain and bracket so when mounted to the ac the window will close behind it. Hope this helps. Thx RepairUSA
Jul 30, 2007 | Goldstar R5050 Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
