Question about Toshiba Satellite Pro L300 Notebook
How to dismantle l300 - Toshiba Satellite Pro L300 Notebook
Tip
Download Toshiba Satellite Pro L300 Notebook Windows XP Drivers
Download Drivers for Toshiba Satellite Pro L300 Notebook for Windows XP: Toshiba Satellite Pro L300 Notebook is shipped with Windows Vista, which is quite good but most of us dont like Windows Vista. Downgrading Toshiba Satellite Pro L300 to Windows XP requires Windows XP drivers, which you can find on this page. Download all Windows XP drivers for Toshiba Satellite Pro L300.
Download Instructions
When you click on a download link and a new page opens that is of uploading.com,
click on "download free" on that page.
After that wait for the timer to finish and than click on "download"!
Click Link Given Below to get Drivers
http://www.getpcmemory.com/drivers/download-toshiba-satellite-pro-l300-notebook-windows-xp-drivers/
Peace Be Upon you !
on Dec 29, 2010 | Computers & Internet
My toshiba l300 can't even power.the led lights are not coming on.i have tasted the charger and it's working
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jul 22, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba L300 Case Repair !
Basically the input power socket need to be replaced. To get at this power socket will require the laptop to be completely dismantled to remove the motherboard to gain access to this power socket. If you find this too dificult to DIY then I suggest you get a quote from a computer repairer before you get this job done.
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba L300. The battery doesnt charge. When plugged in, no power is coming into the unit so cannot use.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 13, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
101 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
