Question about Casio Exilim EX-S500 Digital Camera
Casio s 500 exfilm
Screen blank except for a centimetre at the end of the screen which is normal. camera was not dropped or damaged in any way. Can you help
  • Mike Johnson
    Mike Johnson May 11, 2010
    is the back light lite up? if so can it still try to take pictures? Also if its just dark then hit menu look real hard to see i you might be able to see a image at all. could be 1 of 3 things LCD, Lens, Main board. With out proper diagnosis I cannot properly diagnosis your camera. Hope this helps.
6ya staff
SOURCE:
Anonymous
  • 135 Answers
SOURCE: camera screen dark
It sounds like you broke the backlight on the display. I would contact Casio to find a repair center.
Posted on Feb 16, 2007
Anonymous
  • 47 Answers
SOURCE: lcd monitor screen stays black
Hey i found this site that is great on how to change a LCD for the camera
http://digitalcamerarepair.googlepages.com
Posted on Nov 27, 2007
Anonymous
SOURCE: Casio camera LCD screen broken?
I wouldn't buy this camera. The screens brake very easy.I bought mine from PRESTIGE CAMERA.THEY SOLD ME A WARRANTY THAT IS A RIPOFF.They told me the warranty would cover anything but they layed to me.BE AWARE OF PRESTIGE AND THE WARRANTY THEY SELL>
Posted on Jun 14, 2008
Anonymous
SOURCE: blank screen
same thing happened to me, i really dunno what to do... help? anyone?
Posted on Aug 18, 2008
Anonymous
  • 34 Answers
SOURCE: the screen is black and
Are the pictures also black?
Is so the main circuit board in the camera is probably faulty. This is expensive to replace.
If the Pics are still good it could be the display has been turned to off or the lcd has been damaged and/or back light is not operating.
If you could give some answers to the above we might be able to norrow down you issue further. Please also advise exactly what model Casio you have.
Posted on Nov 16, 2008
Screen will not come on, changed the battery with a new one and charged it . will power on but the lcd screen is blank
If the camera experienced any sort of physical or liquid damage, the LCD screen is always the first thing to go on a point and shoot. You will need to have the camera serviced by Casio or a certified technician and you'll be looking at a repair bill for approximately $250 CAD. If there has been no damage, you might have a burned out screen which would result in the same solution as above, or you can check to see that you haven't switched the screen off. Press the top button that should have the text "Display" above it, this is the top quarter of your square button with a center button in the middle.
Dec 08, 2009 | Casio Exilim EX-S500 Digital Camera
SONY DSC-T70 blank screen! touch screen camera T^T!
The same thing happened to my Sony DSC-T70 today after I dropped it. White screen with green vertical lines. Need help!
May 11, 2009 | Sony DSC-T70 Digital Camera
Nothing shows on viewing screen
I had something like this occur with a minot mini video camera only it locked up in the "On" setting, meaning I could see a display on the screen but could not turn it off. I suggest you look very closely for a reset hole at the bottom somewhere, a place where a safety pin or the straightened end of a paper clip could be inserted. If no Reset can be found, then try holding in the Power On/Off for as long as 90 seconds. This may clear the problem. I would also suspect no power due to low charge or no charge on the battery, battery installed incorrectly, or battery not charged up.
Dec 10, 2008 | Casio Exilim EX-S600 Digital Camera
Casio ex z60 was dropped, screen is intact no image from ccd
YOU STATE THAT THE CAMERA PLAYS BACK PREVIOUS IMAGES? ARE YOU STILL ABLE TO TAKE PICTURES? IF YOU ARE, MOST LIKELY THERE HAS BEEN SOME DAMAGE BETWEEN THE IMAGE PROCESSOR AND THE LCD. THE FACT THAT THE MENU AND OTHER IMAGES STILL WORK MEANS THE LCD IS OK, SO YOU HAVE A CHOICE TO HAVE THE CAMERA REPAIRED TO CORRECT THE DAMAGE FROM THE IMAGE PROCESSOR TO THE LCD, BUT I BELIEVE THE REPAIR COST WILL BE MORE THAN THE COST OF THE CAMERA. I FOUND THE CAMERA ON EBAY FOR A STARTING BID OF $9.99. SORRY, BUT I JUST WANT YOU TO HAVE ALL THE INFORMATION. IF YOU NEED MORE HELP, REPLY TO ARCLIGHT1217. IF THIS HAS BEEN HELPFUL, PLEASE RATE, THANKS!
Nov 30, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blank screen
Aug 15, 2008 | Casio Exilim EX-V7 Digital Camera
Nothing transfered from the lens (ccd) to the screen/memory card
Greetings Maltheskalle,
Units that experience water damage are normally irrepairable even after drying out. I would take it to a qualified repair center and have them give you an estimate on repairing the unit. You may find that replacing the camera is more economical than repairing it.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 10, 2008 | Kodak EasyShare CX7525 Digital Camera
Blank screen
Usually it's an lcd burn out where the screen needs replacement. Check the display button if it's just blank then press it to see if it comes on. As far as your friends white screen it not feasible to repair. A good thing to get on any digital equipment is an extended warranty. It does save you in the end when something goes wrong. The limited manufacture warranties are a joke. You should never rely on them.
May 28, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Blank Screen
ok casio luver you have eather a broke lcd or a damaged main board. visit www.digitalcamrepair.com for more help.
May 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Nixon coolpix L11
if the resulting images are the same, you have damaged the camera settings/controllers. see how they look on your computer.
if only the display on the camera is damaged, you should consider asking for a flat rate repair. most makers offer a price for major and minor repairs, and never charge beyond that.
good luck
mark
Nov 25, 2007 | Nikon Coolpix 5700 Digital Camera
Lcd monitor screen stays black
there may have been some kind of damage to the lcd. sounds like you are going to have to send it in to have it fixed.
Jun 13, 2006 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
