Question about RTO Mobil Line Mobility Scooter Chair Battery Charger31004
I have an electric scooter chair that would charge, do i need to replace the battery? i had not charged it for about a year and i think the batteries are drained. I tried to charge it and it is not holding a charge
  • 177 Answers
Hi. Sounds very much as if your batteries need replacing. Batteries loose there ability to hold a charge if they are left for long periods of time.
Some times repeated charging and discharging will help, but will not be as good as new ones. Good luck. Neil.
Posted on May 30, 2010
My chair has been sitting for three years now won't take a charge and run did the main battery die
Time for a new battery. The worst thing you can do to a battery is let it sit for a long time. Once the battery was activated it is best to keep it charged while not in use. Use a trickle charger while storing your chair.
Aug 26, 2016 | Hoveround MPV5 Electric Wheelchair - Used...
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
R6 300 batteries charging negative
If you connected the voltmeter correctly and you get a negative reading then the batteries have flipped polarity.Get an automotive battery charger...preferably a NON automatic kind and charge each battery separately. Before you take them out of the chair...run both batteries completely down. Connect the charger correctly and charge normally. It will take a longer time to charge that way because the polarity has to change back. Test the batteries again using a correctly connected voltmeter . If the reading is back to positive then you're ok. If not then trash the batteries and get new ones. Radio Shack carries the correct batteries and are much cheaper than buying them from a chair service company
Jan 24, 2014 | Electric Mobility Shoprider Electric Power...
I have a brand new scooter the batteries wont hold the charge
Bill have them replace the batteries. They are under warranty for 6 months and the provider is responsible for providing free replacement batteries under warranty. If they won't contact the manufacturer of the chair and explain your problem (that the provider will not replace bad batteries) they should require the provider to give you new batteries or send some to you. Make sure that you charge the new batteries before use and that you charge them nightly for 20 days If you use the scooter daily charge it every nite when you go to bed and unplug it in the morning hen you get up. Remember to have the power off to the charger whenever you plug or unplug it from the scooter. if the charger is an onboard one then just plug it into the wall and unplug when charged Hope this helps
Apr 08, 2011 | Electric Strider Mini 4 Wheel Mobility...
My battery is not charging
Does your charger's lights come on and does the second light turn green after an overnite charge? If not then you will need to contact your provider and tell them about the problem it should be under warranty if your chair is less than a year old. Hope this helps you
Sep 05, 2010 | Echo 3 TE SL7 3 New Electric Scooter by...
Battery will not charge
Those batteries are probably dead, you have to charge them every so often if you are not using your scooter or chair. You also have to move it so the tires don't wear down and go flat.
May 17, 2010 | Drive Medical Daytona Standard Scooter 4...
Mobil Line Battery Charger for Stairlift not working
check the sensor at the top of the track and make sure it is not loose.Just had this problem,can be fixed with a screwdriver for free.
Mar 26, 2010 | RTO Mobil Line Mobility Scooter Chair...
Shows full charge,goes ok for a little while but then stops turn off then on goes very slow for seconds then stops again.
Hi Susan, I repair power wheel chairs, Its possible that your chair has a bad battery on it , all p/chairs have 2 batteries.And even though you show a full charge one battery may have a bad cell in it you need to get both batteries load tested . I think you my find one of them bad. take them out of chair and have them tested.You can get replacement batteries , and have yours tested at a store that sells batteries only, look in yellow pages for a battery store . Good luck, Erik
Mar 01, 2010 | Electric Mobility Shoprider Electric Power...
My chair isn't charging and has stopped running...
How long have you had the batteries? After a few years all batteries eventually need to be replaced. You can find a replacement battery at http://www.batteryinternational.com/electric-scooter-batteries.html Hope that helps
Sep 16, 2009 | Electric Mobility Invacare Pronto M41...
RTO Mobil Line Mobility Scooter Chair Battery Charger31004 Logo
170 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
