Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
How do you thread a poulan pro weed eater? - Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
  • 109 Answers
SOURCE: idels good but when i start to cut it bogs doun
Either the spark arresting screen is clogged with carbon, or the carb is out of adjustment on the high speed jet.
Posted on Apr 22, 2009
#1 Taper
  • 1040 Answers
SOURCE: Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
Posted on Jun 16, 2009
  • 94 Answers
SOURCE: Can't find fuel filter on Poulan Pro weed eater.
Where is the fuel filter?
All gasoline engines have a fuel filter on the end of the fuel line in the fuel tank. Weed Eater recommends changing the fuel filter yearly. To remove the filter,
1. drain the fuel from the unit,
2. Pull the filter from the tank through the gas tank opening and remove it from the line,
3. Install the new filter on the fuel line and drop back in tank.
Posted on Jul 08, 2009
#1 Taper
  • 1040 Answers
SOURCE: my 2 cycle poulan pro weed eater won't start.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see day light through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
SOURCE: My husband took his Poulan Pro 31 cc weed
Go to the Poulan web page http://www.poulanpro.com/node6556.aspx and enter the model number of the string trimmer. If the trimmer is a Weed Eater brand (owned by Poulan) then go to this page http://www.weedeater.com/node6507.aspx. I think you can also locate older model manuals in their archives.
Posted on Apr 11, 2010
Testimonial: "This was exactly what I was looking for ! I was off by one number on the model number, but I got that straight and this info was spot on, THANK YOU !!"
Poulan pro troubleshooting
Try changing the fuel filter in the tank.
Jul 12, 2014 | Poulan/Weed Eater PP030 966805501 Poulan...
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the oil ratio for the poulon pro link weed eater
Hi brochon
Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
My husband took his Poulan Pro 31 cc weed eater/trimmer apart and now needs an engine diagram to put it back together. Where can I get a downloadable one ?
Apr 10, 2010 | Poulan Garden
Clutch brake assembly
I went to Poulan.com and looked at an IPL for a PP4620???, can you say worthless boys and girls? I provide it in case you need parts.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
This thread is dedicated to your saw. Join, post your need and someone wil snap a photo and post or PM it to you.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/showthread.php?t=115309&highlight=poulan+4620
HTH Lou
Feb 22, 2010 | Poulan Pro Chain Saw 46cc 20"
Can an overheated chainsaw be repaied?
Probably; Piston and cylinder on a homeowner saw may come close to replacement cost.
Poulan pro parts can be found here:
Poulan.com
Find your model number.
Sometimes the cylinder can be salvaged but it involves use of muratic acid. Some threads that discuss this can be found here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I searched on "clean cylinder" and got many hits. GL
Lou
If you attenpt this exercize care.
Oct 06, 2009 | Poulan Pro Chain Saw 46cc 20"
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan Pro weed eater won't accelerate.
check the fuel mixture screws on carb high should be turned in & 1 turn out & low side should be turned all the way in & 3/4 of a turn check those & let me know thanks wade
Jul 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
142 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
