Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
Its coughing but wont start
Just picked it up at a garage sale and it wants to start but it keeps dying cant tell if its in the high or low position for the throttle switch is high all the way forward or to the rear ??
  • 420 Answers
You may want to check the flywheel key too, remove the rewind housing cover followed by the rewind hub on the flywheel, they the key is visible. Any deformation of the key at all and the mower will not run right.
Posted on Jun 01, 2010
2001 buick lesabre would not start, mechanic said bad MAP sensor and water in fuel drained and replaced fuel, and new MAP installed. Car died again on way home from garage. Mechanic said bad Fuel Filter...
This is the piecemeal approach to automotive maintenance. Take your Buick to a competent mechanic to have stored codes retrieved which will identify probable causes for the problems you are experiencing.
Jan 25, 2014 | 2001 Buick LeSabre
Car died. Cranks, but wont start. Codes P0328, P0340
Yes, if the camshaft position sensor has failed, your vehicle won't start.
Jun 11, 2013 | 2004 Nissan XTerra
50cc Scooter won't rev up, Keihin PD18J carb
my 50cc scooter will idle at first and rev very well but wont idle what can this be
Jul 08, 2012 | Motorcycles
Truck wont start red light keeps blinking fast keep hearing clicking under the hood and in the cab dont know what happened got in the truck to start it, and had driven down the road and it died. now the...
THAT SOUNDS LIKE LOW VOLTAGE. PUT A VOLTMETER ON THE BATTERY WHILE TURNING THE KEY IN THE START POSITION. IF THE VOLTAGE DROPS BELOW 8 VOLTS, THAT IS TOO LOW. BATTERY NEEDS TO BE CHARGED OR REPLACED & TERMINALS CLEANED. IF IT STARTS CHECK THE CHARGING SYSTEM. MOTOR RUNNING, VOLTAGE AT THE BATTERY SHOULD READ 13.90 TO 14.90. IF IT IS TOO LOW GET THE ALTERNATOR TESTED.
Jan 08, 2011 | 2004 Ford F150
Poulan Pro PP165H42A. Was running OK. Started coughing and died. Got it to start and got back to the garage with it poping and sputtering. Assumed low on gas. Some gas remained (1 1/2 inch)while I...
You need a new starter solenoid. Just bring your model number with you to the small engine repair shop and tell them what you need. DON'T let em talk you into a new starter or starter repair kit.
Nov 01, 2010 | Poulan Garden
2000 Blazer Cranks, Won't Start
First of all, a diagnostic wont tell them that there is arcing involved. I am thinking it is your crank sensor. It expands and retracts in different weather situations.It should make contact in all weather situations.
Feb 12, 2010 | 2000 Chevrolet Blazer
Engine wont accelerate and coughs when trys to get to high revs
Hi Odoggg, and the usual suspects are:
1. Faulty crankshaft seals, do a visual inspection and pressure test.
2. Power valve failure.
3. Faulty high output coils or CDI
4. Float level too low, restricted main jet, fuel tank not venting.
5. Restricted exhaust port or clogged expansion chamber. I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day. DOWNLOAD 2008 Aprilia Rx 125
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 08, 2009 | Aprilia RX 125 Motorcycles
FXR suzuki 150 will idle but wont rev
i had the same problem ! i dont know how but there was water mxit in my tank and i dumpd the fuel then it was fine
Mar 16, 2009 | 2001 Suzuki FXR 150
Fiat punto no spark wont start
check you camshaft position sensor
Feb 01, 2009 | 1990 Buick Reatta
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
132 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
