Question about Xerox Phaser 8550DX Laser Printer
Xerox Phaser 8560 started printing with an inch black line.
We have a Xerox Phaser 8560 and it has just started printing with a dark (composite black) but varying shades on the left hand edge of the paper about 1" thick - we have tried cleaning the drum, the maintenance wiper and using the various cleaning menus and sometimes it helps for one sheet and then it is far worse - had the printer for about 2 years with no problems so far - should we buy another?
  • 1,675 Answers
Hi i think buying a new one might be a bit drastic, this could be a couple of things, mainly is the toner supply try to the heated drum putting out enough ? is it blocked at one end? ( ie the end that has the faint print ) is the heated drum defective? this would be a major repair, but i think it will still e cheaper than getting an equivalent printer of this type, although there are now allot of very reasonable printers on the market, but it defiantly sound more like the supply of toner to the drum it might be worth the investigation, all you might need to do if purchase some white spirit to clean the toner supply tray out...hope this helps
Posted on May 29, 2010
  • gary_lowe165 May 30, 2010
    Thanks for your reply - the problem is the thick line is all the way down the page (sorry the right hand side not the left) and seems to improve with a little cleaning of the drum and maintenance wiper and then gets very dark in colour - where can I check whether there is a blockage to or on the drum?
    Further to my previous email I have left the 8560 printer off overnight and this morning it is now printing nothing on the right hand margin of the paper - does this indicate that the left hand side of the drum has lost its charge or whatever it needs to attract the wax?
    Many thanks.
Xerox phaser 8560 says "paper jam - open front
try cleaning the microswitches. it may also have a sensor and if the little plastic piece that crosses between them has broken off it will throw codes. mine is ok so i cant say for sure but you can try to glue a suitable piece in there to trick the printer if thats the case or bypass the sensor. just a few suggestions from my experience with electronics
sensor is kind of this: gap is where the plastic part is supposed to go in between.
Oct 12, 2011 | Xerox Phaser 8560MFP Laser Printer
How do I print on 4X6 photo paper on the Xerox Phaser 8560
To print 4 x 6 on a Phaser 8560 you can only use the MPT and you can't duplex. When you load the paper into the bypass, the screen will pop up options for paper size and type. The closest match to 6 x 4 is A6 but the tray will know that the size is wrong if you select it. Therefore, you must select 'Custom Size' and input the size in whatever units the printer requests, either inches or millimeters depending on your printer settings.
Hope this helps.
Nov 28, 2010 | Xerox Phaser 8560MFP Laser Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
2 sided copying
You just select 2-sided printing in the print dialog box. I think it's on the finishing tab. I'm assuming you aren't trying to print on 2nd side of pre-printed stock. That would be a different issue.
Apr 09, 2009 | Xerox Phaser 8500/DN Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Enquiry for best latest machine
The 856o is solid ink printer. DN is the duplex version of the 8560. Price should be less then $900.
All print features are available on it. The hard drive is optional.
  • Rich, vibrant colors on everything from cover-weight stock to recycled paper
  • Adobe PostScript 3 and automatic color enhancement tools ensure reliable and accurate prints learn about Xerox Color Correction (PDF)
  • 2400 FinePoint™ print resolution produces incredible detail and halftones you'll be proud to share
  • Consistent, vivid color from the first page to the last
collapse_off.gif more features
  • No penalty for color because the Phaser 8560 prints black-and-white and color at the same fast speed
  • High monthly duty cycle of up to 85,000 images means you'll get a reliable color printer that will last for many years to come
Features that Enhance Ease-of-use
  • Easy to install on your network with only a few clicks See how easy it is to install
  • No toner cartridges! Just drop the no-mess ink sticks into the Phaser 8560's shape-coded slots, close the cover and you're done
  • Instant on-screen alert notification and help when a print job needs attention thanks to Xerox PrintingScout™ technology
  • Access device and job status as well as accounting information from your computer via the Xerox CentreWare® IS Embedded Web Server
  • Prints are secure with Saved Print feature, which won't print your job until you enter your PIN on the front panel (requires hard drive)
  • Electronically "shreds" data stored on the hard drive after every job or on request (requires hard drive)
  • Real-time paper tray status on your desktop shows all available media types and sizes
  • Up to four paper trays can a hold a variety of media types and sizes
  • Automated online troubleshooting with PhaserSMART™ gets you back to work fast
  • Booklet printing feature automatically arranges your document so you can easily fold and staple it into a booklet (requires two-sided printing)
  • Job completion notification lets you know when your print job is finished
  • Run Black allows printing to continue in black-and-white if one or more of the color toners are depleted
  • Print With feature prints your current job (such as a cover letter) along with other jobs stored on the printer's hard drive that you specify (such as a brochure or two)
  • Personal Print feature can create your own private mailbox on the printer's hard drive where your processed print jobs are stored for quick printing via the front panel or embedded web server
Software Solutions Digitize . . . Organize . . . Distribute . . . Collaborate
With digital documents, you can easily create, search, re-use, and build upon your documents. Maximize your hardware investments with innovative software solutions from Xerox and Xerox Business Partners:
  • Contain costs
  • Share knowledge
  • Accelerate workflow
  • Integrate paper and electronic documents
  • Manage and distribute documents effectively
> Show me the Software Solutions
Pricing Details Prices do not include applicable taxes, shipping, or handling charges and are subject to change without notice. Products are available to qualified business customers installing in the US; subject to applicable terms and conditions, and may be either Newly Manufactured, Factory Produced New Model or Remanufactured; which have been produced to a Xerox pre-determined standard and may contain both new components and recycled components that are reconditioned.
1 Average standard pages. Average Continuous Composite CMY Yield in accordance with ISO/IEC 24711. Yield will vary based on image, area coverage and print mode. Read our Consumable yields guide (PDF) for more information.
2 Approximate pages. Declared Yield on Drums based on an average job size of 3 pages A4/letter size. Declared Yield on Fusers based on A4/letter size 20 lb (75 gsm) pages. Drum and Fuser Yields will vary based on job run length, media type, size, weight, orientation, and usage patterns. Read our Consumable yields guide (PDF) for more information.
Mar 07, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser  8550DX Laser Printer Logo
161 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
