Question about Dell Dimension 3000 PC Desktop
No panel lights, no fan, flashing front left light
I was changing out a monitor chord when my Dell Dimension 3000 powered off. Changed cords, plugged into different outlets but all I get is a blinking front light. No diagnostic panel lights light up on the back, no fan at all or any other sound. Took the cover off and there's a solid green light on what I suppose is the mother board. Awfully odd coincidence that it went out while I was moving it, but there it is.
    Sergeant:
  • Dell Expert
  • 464 Answers
The blinking lights means power issue. If you already plugged the computers power cable directly to the wall and stll get the blinking power light then your probably looking at a bad power supply in the computer.
Just for measures go into the system and if you have a video card remove it and start the system up. Also take out the memory stick and put them back in just incase during the move some components got loose. Put on your detective hat and check all connects. if problem still persist replace the power supply. In Computers terms thats called the PSU (power supply unit)
Your friend
Joel
Posted on May 29, 2010
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
Dell Dimension 5100c Model: DCCY will not boot.
Is the power button a steady abmber light?
If so follow the instruction below>>>>
Remove the power cord from the back of the computer. Then open the side casing of the tower and unplug the 24 pin block connector from the motherboard. The 24 pin block connector looks like this >>>>>
Once removed press the on/off button on the computer to dispel and residual power from the motherboard.
Then connect the block connector again and put the side panel back on and then plug the power cord back in and try to boot the computer up.
If its still the same then the power supply inside the computer may need replacing.
Good luck.
Jul 03, 2010 | Dell Computers & Internet
Dell Dimension 9150, flashing orange light on front power button. I noticed an orange light flashes on the ethernet port when plugging in the power cord, but it wont power up? Any suggestion, please help!
The power supply needs to be replaced, How old is the system, Can you provide the tag, i may be able to get you one for little or no cost. if your interested :)
Stephen.cscorp@gmail.com
Apr 14, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My Dimension 5150 box will not turn on! Just blinks, looks like an orange light. Monitor comes on then goes off to orange...
- disconnect the power cable of the box from the back of the tower and press and hold down the power button for 10 seconds (remaining power will be depleted).
- Now try using a different wall outlet.
- Check the diagnostic lights to see if the specific problem is identified (the computer has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel). Also, see "Power Problems" in your computer Owner's Manual and/or Service Manual.
http://support.dell.com/support/edocs/systems/dim5150/en/sm/tshoot1.htm#wp1120147
Nov 03, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing Orange light, computer wont boot
Below is the link to the NoPower, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=falseFollow all the steps without skipping any and if there is no hardware failure,this should definitely resolve your issue.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
No power light when on but can hear running, no screen image
First make sure the monitor is on and connected to the PC.
If the power light is not on you could have a bad power supply, it could also be that the onboard video went bad.
If your PC has four trouble lights in the back, let us know which ones are lit, this can pinpoint the problem.
The noise you hear is the drive spinning up and the CPU fan.
Good Luck.
Feb 22, 2009 | Dell Dimension 3000 PC Desktop
Dimension 3000 Power up problems
Sounds like you have a bad power supply. If your computer is plugged in and you turn it on and nothing happens then replace your power supply and all will be well. And yes the monitor needs to be plugged into a outlet and also the back of the computer to work.
IF this has helped please rate
Feb 12, 2009 | Dell Dimension 3000 PC Desktop
Boot up problem
Unplug all the Harddrives, Cd Drives attached to the motherborad. Try turning up the system. If it boots, you may to have to change the I/O cables.
Still if it is amber, then your motherboard is having the problem with. As long as the LED glows PCU gotta be okay.
Kindly get back for futher help
Jan 09, 2009 | Dell Dimension E510 PC Desktop
Dell Dimension Shut Down
Hi
You query suggest you have Dell Dimension 3000. Dell Dimension 3000 is a desktop PC and does not have a battery backup by itself.
I am assuming the battery backup you are referring to is a UPS (Uninterruptible Power Supply). If this is correct then by your description of the issues, the UPS may be faulty (indicated by the Red light and beeping).
Disconnect the computer's power cord from the UPS and connect it to a wall power outlet to confirm or rule out the UPS as the offending device.
If this does not help reply with more info
Mike
Aug 15, 2008 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 PC Desktop Logo
234 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
