Question about Whirlpool Duet GHW9150P Front Load Washer
F2 is flashing washer wont start - Whirlpool Duet GHW9150P Front Load Washer
    Novelist:
  • 77 Answers
The F 02 errors in these machine means "Long Drain". 9 times out of 10 this is an issue with the pump. Pump problems plague these machines, not because they are faulty, but because things get inside them. Foreign objects like pencils, paper clips, etc. Generally you can remove the obstruction and resume using the washer. If you are unlucky, something damaged the pump and it will need to be replaced. Naturally there can be other causes to an F2 error, but this is the most likely.. by a loooooong shot :)
If you are a do it your self type of person, I can tell you how to take care of the pump yourself. This would require some tools and might get a little messy tho. Glad to help either way!
Depending on where the pump is purchased, it can cost anywhere from $120 - $200. good luck!
Posted on May 30, 2010
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Problems with compaq presario cq56
open f10 go to diagnostics 10008 bios code means the hard drive is fried new one for cq 60 160gb hard drive 90 dollars but might as well upgrade 500gb only 115 i would think the cq 56 should be about the same price
Apr 01, 2012 | HEWLETT-PACKARD Computers & Internet
My Duet front loader.. once it starts washing it stops and an error f2 code comes up and it will not complete the washer the clothes are left wet. if i move to spin only it still wont same code comes up
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code flashes and machine wont finish the drain cycle
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 30, 2011 | Siemens WXLP1460 Front Load
I have an HE 3 front loading washer and I am having problems with
Hi
Thanks for using FixYa. F2 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F2" is flashed. Press PAUSE/CANCEL twice to clear the display. Also, check the drain hose and make sure it is not plugged or kinked. Then check the electrical connections at the pump and make sure the pump is running. If still the issue is not resolved then replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Kenmore Elite 45986 Front Load Washer
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool washer need to be repaired
The f2 code is a pump problem. Need to look in pump. It is the first cycle to be satisfied when started.
Oct 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal De
