Question about HP PhotoSmart C4480 All-in-One Printer InkJet
The printer won't stop printing, nor will it print the item I selected to print; it just  keeps spooling and spitting out paper.  HELP!!
  • 1,675 Answers
Hi this sounds like you are using the wrong driver for the printer, does it just spit out gobbeldy gook on the paper? if so this is the reason, un-install the printer driver you have currently for this printer and go to
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=uk&dlc=en&sw_lang=&product=3418705#N644
here you will find the correct driver for your printer i have chose the page allready, i dont know what OS you are using, but i chose the xp drivers, if incorrect, just click home page for hp and do it again till you get your OS drivers...hope this helps
Posted on May 29, 2010
Testimonial: "Thanks, Steve!! You fixed me!! Have a great weekend!"
Spools will not turn
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service. When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
Aug 21, 2012 | Office Equipment & Supplies
What mean pc printing ? and out op paper?
Hi. This means that the computer has still printing or there are print jobs on queue. You can cancel the print jobs on queue and restart the print spooler service by following the steps below:
  1. Click "start" and go to "Run"
  2. Type "services.msc" at the prompt which will open the Services
    window (ooh, pretty...)
  3. Scroll down the alphabetical list in the right window pane until you come
    to the entry with the name "Print Spooler"
  4. Right-click this entry, then select "stop". This will stop the computer
    running the process that holds your print queues.
  5. Leaving that window open for now, click again on "Start", and then click
    "My Computer" to open a Windows Explorer window.
  6. We've stopped the queue service, now we just have to clear the jam that is
    already there. To do this we navigate to the print spool folder which is hiding
    within the Windows folders. Usually Windows is installed on C: drive, but you
    should be easily able to tell when the Explorer window opens which drive it is
    on.
    The usual path to the spool folder is
    C:\\WINDOWS\\system32\\spool\\PRINTERS, but yours may be slightly
    different. Your windows drive may have another name for instance, but this would
    be uncommon. So click on your Windows drive (usually C), then double-click on
    the Windows folder, and then find the System32 folder and double-click on
    that. Windows may warn you that you are about to view system files, but click
    "View files anyway" message and search out the "spool folder". Within the
    Spool folder is your Printers folder, and you should open
    that.
  7. Delete every file within this folder to empty the jammed print queue
    (pressing the "ctrl" and "a" keys will select all files and then you can just
    hit "delete").
  8. Close the explorer window now that we have emptied the cleared spool files,
    and return to your Services window. we must re-start the Print spool
    service, and do so by right-clicking the Print Spool entry and selecting
    "Start" from the list. Close the services window and try printing again
Jun 07, 2012 | Panasonic DP-CL21 Laser Printer
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
Printer stuck on spooling
Try the steps below to fix the spooling problem:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 09, 2012 | Lexmark X5650 AllInOne InkJet Printer
Dell AIO printer prints only portion of page then stops! Sometimes up to 30%
hi normel_brabs,
you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then remove the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press.
NOTE: IF YOU HAVE ANOTHER PRINTER INSTALLED, DON'T DO THESE STEPS, JUST RESTART THE COMPUTER.
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
Oct 16, 2009 | Dell 810 All-In-One InkJet Printer
Scans stop at 99% and make the entire prog (all in one software)not responding as well as printer freezes between a double sides printing (after finishing the pages on one side)
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
From the start search box type spool and press .
LexBce Server
Print Spooler
good luck :)
http://tinyurl.com/yddyuw6
Sep 24, 2009 | Dell 926 All-In-One InkJet Printer
My Dell Photo Printer 720 has stopped printed, no response at all to print jobs. I have unplugged the printer, no change. I have rebooted the computer, no change.
hi there,
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
Aug 03, 2009 | Dell Inkjet 720 Printer
Lexmar Z611, How do I delete 20 items in printing queue?
Goto Start click on Run type in Services.Msc and hit ok.............. Now on that list select the one which says Print Spooler right click on it and click on Stop........ Now go to Run again type in Spool and Hit Ok............ on that window click on Printers....... Delete all the items under Printers............. Close that Window............. Now Right click on the Print Spooler and click on Start............. Now Uninstall the Software........... Download the Drivers from the website............Install the Downloaded drivers....... It Should work............ Thanku
Jan 12, 2009 | Lexmark X1150 All-In-One InkJet Printer
Print spool service is not Running
What makes you think the print spooler is not working? Is it because you get a message saying that it is not working or is it because you cannot print?
If you can stop and start the print spooler that would indicate to me that the spooler is running and you have a different problem. It is probably a corrupt print job, to fix this do the following.
1) stop the spooler
2) go to My computer
3) select the C drive
4) select the windows folder
5) select the system32 folder
6) select the spool folder
7) select the printers folder
8) delete everything in the printers folder
9) restart the spooler
Sep 30, 2008 | Computers & Internet
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
120 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
