I have a Samsung HL-S5687W 56-Inch 1080p DLP HDTV that turns off randomly. I have checked the warning lights for the lamp and there is no indication that the lamp is weak. Also the picture is fine while the TV is on. I have read a few threads on this website and found several owners experience the same problem and have suggested things like buying a small fan and/or vacuuming, etc. Are these good suggestions that I should try? And if they are, can you tell me a step by step procedure on how I would go about doing some of these suggestions. Like exactly "what" do I vacuum? Do I need to open any doors in the back?
  • 4,472 Answers
There are a lot of possibilities here. This could be some parts that need replacing but there are some easy things that can be done for free that just take a little time. Along with the sleep timer there is an auto off timer on the set, check that. Also the lamp cover door, unscrew it open it and retighten it. Check the power cable to make sure it is snugly in place as well. You can also do a reset by unplugging the tv and holding the power button for 30 seconds. Do all those first, then you may have to consider repair for the set as their are a couple known issue's with these sets and samsung could definitely help you with getting it repaired(at your cost of course as the tv isn't under warranty any longer).
If you need further assistance let me know.
Thank you and good luck,
Lee
Posted on May 29, 2010
Samsung DLP has gone darker
The 60 K hours is bogus---Average life on a OEM lamp is 2,000 hours or two years average---if you got four or more years you were lucky.
To your problem---
Jun 13, 2012 | Samsung Hl-s5687w 56-inch 1080p Dlp Hdtv
My Samsung HL-s5687w turns on only for 3 minutes then turns off standby/temp timer lamp start blinking what dose it mean
Lamp and or ballast are most common BUT did you hear before a high pitched or fan like sound before this happened?
Apr 08, 2012 | Samsung HL-S5687W 56" HDTV
I am having problems with my Samsung HL-S5687W 56 in. HDTV Television It is turning on ok then shuts off after a minute or so.Do you have any recommendations
i have seen before that model have some problems with the lamp door switch. check the back of the tv and make sure that the lamp door is secure otherwise it can be possibly a color wheel or even lamp failure. if you have never replaced the lamp then i would lean more towards that as the root of your problems.
Jan 06, 2011 | Samsung HL-S5687W 56" HDTV
When we turn the TV on, a red light starts to blink but no image or sound is displayed. How can this be fixed?? And What is causing this? my TV model is HL-s5679w
The Blinking light is an error code, most likely you just need to replace the bulb which is fairly easy, there is an access panel on the back and you should be able to replace your self. A new bulb should include basic instructions here is a link price is $110
http://www.buy.com/prod/samsung-hl-s5687w-hls5687w-bare-lamp-bp96-01472a/q/sellerid/28565179/loc/111/215199305.html
Sep 14, 2010 | Samsung HL-S5687W 56" HDTV
Samsung HLR5667W 56-Inch DLP HD TV not working
A black and white picture usually indicates the color wheel has failed or the DMD board has failed. Call 1-800-samsung to find neaREST SERVICE CENTER.
Jun 16, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HL-S5687W dlp tv, the picture is darker than usual and getting darker by the day
Hi
Well for what you describe it sounds like the symptoms of a worn out lamp giving you the last kicks,basically the the lamps are design to go for 6,000 to 8,000 lamp hours if they're Phillips and a generic lamp could give you 3500 to 4500 lamp hours so with this in mind you could search for a new lamp at Discount-merchant.com or you can go to Ebay also you can go to www.fixyourdlp.com for more troubelshooting
Please rate this if it was helpful.as I do this for free.
Regards
Jan 05, 2010 | Samsung HL-S5687W 56" HDTV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP
try this and see if it makes a difference
open the lamp door look for the blue switch(bottom left i think)
take the loose wire(blue and white) wrap it over the switch to hold it back
and while your back there make sure you dont have a lot of dust blocking the vent on the back cover
Mar 11, 2008 | Samsung HL-S5687W 56" HDTV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
