Question about Sony KP-61V85 61" Rear Projection Television
What could the reason my tv projector light up and off
    President:
  • 1,099 Answers
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck
Posted on May 29, 2010
Why can I hear 50 rear projection tv no picture yes on sound?
The projector and the audio system for the TV are completely separate. There are many reasons your projector may not be working, however it's failure will not always effect the audio which runs through it's own circuits and amplifier to the speakers. Think of this as if you had your computer's VGA out plugged into a projector and the mini audio output plugged into amplified speakers. One will not effect the other unless your problem is a loss of power.
Aug 28, 2014 | Televison & Video
White spots on ep7155
Dear Sir,
sorry, lately answer your question, and every days was very busy, and i operate a trading company on construction materials, such as plywood, MDF, furniture, etc. so have much work to do, and just login fixya meet all warm heart friends by off hours.
meantime, i'm amateur of electronic products, and glad to answer some question what i know, kindly hope i can help someone.
under the support of many friends who comes from Fixya, i open a ebay store, specially supply projector, and DLP HD TV sapre parts, such as color wheel, DMD, lens, lamp, boast, mainboard, remote control, light tunnel, etc.
sorry, saying so much words, back to your question.
firstly, inspect the connect cable, then note some outside signal disturb, if you exclude these two reason. perhaps you should find a repairman help you to remove dusty. if all these action can't solve with your trouble, you have to think about the reason of DMD.
hope above words be useful for you,
for any further communication, please freely contact me,
best regards
Jack,
email: flying200809@gmail.com
when you need projector color wheel, lamp, mainboard, DMD, lens, etc sapre parts, please don't hesitate to contact me,
Jan 07, 2012 | Optoma EP7155 Projector
Looking for replacement lamp for Sanyo PLV-WHD1 TV Lamp type # POA-LMP96 service parts # 6103227382. Need some help finding one that is compatible for reasonable price.
You can get replacment lamps for this TV from www.TvRepairKits.com
Models Supported = PLV-55WHD1, PLV-65WHD1, PLV55WHD1, PLV65WHD1 ,PLV-55WR2C, PLV-55WR2CH POALMP96 , POA-LMP96 , 6103227382. and more.
Feb 03, 2011 | Sanyo Genuine Original 6103227382 ...
Lamp light flashing when projector turned on.
Ordinarily this is not a problem. usually this happens to virtually every projector at start up. Reason is the projector needs to warn up before it project/beam unto the screen. But if you are saying it continues to flash endlessly, that is another issue. At any rate that doesn't seem to be the case since you didn't say so.
Sep 04, 2009 | Canon LV 7525 Multimedia Projector
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
Epson s1
hi-
before you send it to a repair shop pls try to remove all the devices that you attach to it and check if you are still going to get those light whites after awhile, or try using a different device in which it uses a different cable, did you attach a receiver as well from the tv to projector? try changing the cables as well. update me after you performed this steps, if it resolve it pls rate as fixya if not pls reply back. Thanks!!
May 10, 2008 | Epson EMP S1 Multimedia Projector
Lg 50'' dlp tv
hi my is the same do you have a solution yet?
Feb 26, 2008 | LG DLP Projector 1400Lum RD-JT30...
Yamaha LPX 500 home cinema projector isn't lighting up
The reason for a red light is replacement of lamp or it is running too hot. Have you checked for proper venting, and cleaned them recently. The bulb usually lasts 2000 hours, so you may need another.
Jan 27, 2008 | Yamaha LPX500 Multimedia Projector
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
Dec 16, 2007 | Philips Televison & Video
InFocus Proxima UltraLight LS1 LCD Projector
There could be several reasons for this problem.
1. New lamp needed.
2. New lamp did not fix? Could be mirror tunnel behind the color wheel than can collapse causing "dim" light source or dark lines.
3. All items "greyed" out caused when the unit does not sense a source input, ie computer or tv tuner. After connecting to a source, you should be able to go and adjust contrast and/or brightness settings
Oct 01, 2007 | InFocus X1 Multimedia Projector
Sony KP-61V85 61" Rear Projection Television Logo
54 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
