Question about Mitsubishi MS09TW Air Conditioner
Mitsubishi MS09TW Mr. Slim dual indoor units - one not cooling.
We are renting a condo that has a Mitsubishi MS09TW Mr. Slim with 1 outdoor unit (compressor) and 2 indoor units. One unit is working (cooling properly), but the other is not. It turns on and the fan works (air comes out and vanes move) -- but no cooling. The compressor is working and there is no sign of leakage outside. Can anyone tell me what might be wrong?
SOURCE: Mr.Slim Mitsubishi dual zone system
We had that problem with two units that we just had installed. Both are hooked up to one compressor. After several calls and the service person coming out twice, it turned out that they had two wires mixed up when they did the installation. Once they switched the wires the units ran ok.
BUT...now we are having another problem with the units/compressor not working after losing power in our house. We lose power on a regular basis here. Does anybody know if that means we will constantly need to call the service people to come to get the compressor working again? Or is there anything we can do to reset it? The service person that came today was not very helpful and didn't have a lot of answers for us.
Thanks
Posted on Jul 23, 2008
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 9 Answers
SOURCE: Vane control on Mr. Slim Remote
Pls put the vane on the position 2 and then manually turn the vanes to desired position it will not move until the time you turn the power off and you can enjoy the benefits of Mr slim....
Posted on May 26, 2009
  • 34 Answers
SOURCE: mitsubishi mr slim mn PUL18EK outdoor, PL18FK2
8 flash is a pipe temperature error.
Posted on Aug 13, 2009
SOURCE: Mr. Slim MXZ30TN Air Conditioner: Indoor unit blinks on and off what is the problem?...
continuous flash is frost prevention ...clean the filter & switch fan to high
flashes once every 2 sec could be room air sensor contact loose/short...call dealer
flashes 2x every 2 sec is indoor coil sensor contact loose/short...call dealer
flashes 3x / 2sec sensor contact problem, or compressor overload protection trip or gas leak...call dealer
Posted on Jun 02, 2010
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Mitsubishi mr slim compressor fan won't turn off
The outdoor fan is supposed to be on almost all the time if the indoor unit is on. It is designed to do this due to energy consumption is from the start of motors. These fans use nearly no electric about as much as a light bulb. If your unit is cooling and no problems have occurred then its probably doing what is supposed to
Jul 26, 2013 | Heating & Cooling
Have a Mr Slim. Air comes out but not cool. The green light was flashing. Turn the unit off and then back on and it stopped flashing, but still not getting cold air. Cleaned out the filters as well
i have vast history with this type of unit its like working on a computer all controls are microprosser based send me m# and s# of indoor and outdoor units might be able to help.
Jul 03, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a P8? CAN'T FIND MANAUL
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Mitsubishi electric Mr Slimair conditioning. It runs a few minutes in cool mode, then it stops and an error of P8 code appears. When it runs, the fan is not strong.
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
Hope,it's helpful.
Jan 15, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Its not working and flashing P6. Its a Mr Slim
dear sir/madam i think.... mr Slim A control R407c & R410a systems.
P6 = indoor coil frost protection in cooling or indoor coil overheat protection in heating.
Cooling
One of the 2 indoor coil sensors reads minus 15 deg C for 3 mins.
Heating
One of the indoor coil sensors reads over 70 deg C.
If you are sure the refrigerant charge is correct & system operation is correct then it could be a coil temperature sensor reading wrong temperature.
If you have one of those little monitor things which plug into the outdoor circuit board you can monitor the indoor coil temperature.
On later type remote controllers you can get all operating data like temp sensor data but you will need a service manual to do this.
Or you can measure the ohms resistance of the temp sensors & compare with the chart in the service manual. if you can do it by yourself do if not then contatct ot mitsubishi maintenance personnnel for furhter action, thank you hope answer the question please vote!
Sep 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Fan works, air conditioning does not. Try resetting the power (in the proper sequence - outdoor unit followed by indoor unit). Air conditioning came on briefly (less than a minute) than stopped, leaving...
Without seeing the unit,
1 - the condenser fan (which is in the outdoor unit) could be blown. This would cause the unit to go off on high head pressure.
2 - it could be low on refrigerant, which makes it do nothing but blow room temperature air around. The unit would go off on low pressure
3 - the filter is dirty, blocking the cooling
4 - the compressor could be shorted, or a corroded wire somewhere that feeds the contactor
Mr. Slim Ductless Splits are the best on the market and should only be repaired by a trained technician.
Hope this helps.
May 28, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Thanks
May 18, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi MS09TW Air Conditioner Logo
230 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
