Question about Roundup ScottsRoundUp 0394560 PT Concentrate TougWeedKiller
How much roundup to 1 gal water forwatering can use
How much roundup to 1 gal water for watering can use?
  • 8,197 Answers
6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
Posted on May 29, 2010
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Apr 24, 2011 | Roundup "" Weed & Grass Killer
How much do I water after the roundup is applied
Roundup (glyphosphate) doesn't get watered in. However if the area was stressed due to heat or dry conditions, water before using the Roundup to ensure that the plants are growing and transporting nutrients to the roots. The usual recommendation is 1" per week. Roundup kills all plants that it is in contact with. Then let the product dry before it rains (1-4 hours depending on the formulation read the label for rain-fastness information).
Water the plants that were not sprayed as you normally would as long as the treated areas will not be wetted before the Roundup is dry.
Even the extended control version does not need to be watered in.
If you are using a different product that needs to watered in, please read the label for directions. (For example some pre-emergents need to be followed 1" of rain to water them. Alternatively you can do a shallow tillage of the treated ground (2" deep iirc).)
I hope this helps.
(any directions given in the product label should be followed)
Sep 13, 2010 | Garden
I broke off the rod were the water pump pully is. in my olds aurora 1996 and i dont knw what to do ????? help
IF YOU HAVE THE 4.0 ENGINE ROD BROKE PART OF WATER PUMP.YOU HAVE TO REPLACE WATER PUMP.YOU NEED TOOL J - 38816 TO REPLACE INSTALL AND REMOVE WATER PUMP.YOU CAN BUY TOOL AT ANY AUTO PARTS STORE.TORQUE FORWATER PUMP IS 73 FT LBS. TORQUE FOR WATER PUMP DRIVE BELT COVER IS 89 INCH POUNDS.
Sep 09, 2010 | 1996 Oldsmobile Aurora
How to mix roundup to kill weeds
May 02, 2010 | Roundup ScottsRoundUp 0394560 PT...
How much roundup to 5L of water so I can spray
If you're using pro-roundup or agriculture level roundup mix 1 Cup of roundup to 5 gallons of water. This will give you a mixture between 1% and 2% which will kill most undesirables and anything else that picks up the spray.
Jan 21, 2010 | Roundup "" Weed & Grass Killer
HOW MUCH ROUNDUP TO GALLON OF WATER
regular concentrate 6 fl. oz per gallon
super concentrate 2.5 fl oz per gallon
May 22, 2009 | Roundup "" Weed & Grass Killer
Roundup ScottsRoundUp 0394560 PT Concentrate TougWeedKiller Logo
653 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
