Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have a Hayward HD100DI pool heater (3 years old) that I'm told needs a new heat exchange. I'm told they don't make them available anymore since it's too expensive of a repair to make and you're better off replacing the heater. I believe the problem happened when my daughter left the heater on for several days (water was a balmy 102 degrees), and now water leaks from that area. I'm trying to repair it without replacing. Any ideas on how I can do this? Thanks in advance, Boiling in New Hampshire
  • A Miller Jun 04, 2010
    If you could get the parts ... by the time you have it installed ... and running ... you wil have about the same $ invested fort a new heater ... but you will have a three year old heater. If there is a copper smith in the area ... you might get him or her to repair ... I dont think it will ever be fight however. 102 degrees is dangerous. How is your water? Have you had it balanced? Do you check it? If the water is aggressive, there is a possibility that the water has damaged the heater.
  • Bob Camire Jun 07, 2010
    Thank you for the info. I'm trying one last fix to repair the leak (plumber's epoxy) and if that doesn't work, I'll use it as a boat anchor (all I need is a boat). Thanks for the advice of a copper smith - good suggestion!
    Bob
I just found the same problem after replacing my ingiter and gas valve this week. Leaks right above the new valve. I'm going to try JB Weld, which comes in alot of different applications, and you can get at most Automotive stores. It worked pretty good on an exhaust leak I had once. Good luck and I'll let you know how it works out. My heater is still heating the water but makes a knocking noise when starting and of course, the water is leaking.
Posted on Jun 09, 2010
I had the same problem with a 10 yr old heater. You can get the whole heat exchanger assembly, but it is quite expensive. $700 - 900 depending upon the model.
I found on my exchanger that I had developed a leak in the copper right next to the manifold (large black plastic piece on one end of the copper). I tryed to solder the leak but had no luck from the outside. Dis-assembled the exchanger and tried to solder from the inside of the tube, again with no success. I finally cut the opposite side of the tube that was leaking to avoid steam pressure build up and plugged this one leaking element at the manifold. Here is the funny part, I couldn't find a copper plug to fit the id of the tube, so I used a synthetic cork from one of my wife's wine bottles and high temperature RTV, blue, the same that is used on automotive water pumps. Worked great!
This does reduce the total flow of H20 through the heater core, but solved the leak. I will be replacing the exchanger in the near future, but this got me through the winter and eliminated the water loss.
Posted on Aug 19, 2010
  • 8,404 Answers
Dad burned spel checker ..."I dont think it will ever be RIGHT however ..."
Check the temp on that eoxy you will be using ... of course if this is the last ditch effort ... might as well go for it. Along those lines ... there are lots of interesting epoxy type materials you might consider. Go to the Ace Hardware in your town and look at the offerings on the shelf. 'Liquid steel' might be something for you to consider.
Good luck on your project.
Thanks for your interest in FixYa.com
Posted on Jun 07, 2010
I have a hayward H100ID above ground pool heater. Recently the heater is making a rattling sound and the in and out hoses are bucking or pulsating. The water is still being heated but somehting does not...
low water flow is making the heater knock, (PULSATE) clean filter or backwash, check pump and skimmer baskets and empty. if still low flow and knocking, check impeller on pool pump to make sure it isnt clogged.
Aug 30, 2011 | Hayward Pool & Spa
Five year old Hayward H400IdL2 makes a banging noise when the heater is turned on. Pool man mentioned a bypass valve problem. Leslie's pool said we need a new heater, at a cost of $2,300 (including labor.)
Thank you for posting your question here on Fixya.com.
Does the banging continue until the heater eventually shuts off or does it quit shortly after the heater burners start up? In either case you can repair the heater for much, much less than a new unit. The bypass may be the issue if it is stuck closed. You will also want to inspect the control valve in the header and inspect the overall condition of the heat exchanger. It is likely aggressive water has damaged some or all of these parts causing the banging noise you hear. It is also possible there is an issue with the pump and/or filter not getting enough flow thru the heater but I have to assume your pool man eliminated those possibilities when he looked at the heater.
Was the pool man not able to repair or at least inspect the heater further for you?
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Dec 07, 2010 | Hayward H400idl2 400,000 Btu Low Nox...
We have a less then 1year old heater that is burnt out becuse we put clorine tablets in the skimmers lxi gas pool heater
You owners manual will tell you that putting chorine tabs innto your skimmer will damage your heater and void the warranty. I am sure you already know this now. It is bad procedure to do this. I assume you have a leaking heat exchanger. This is very costly, and you will probably need to call a professional to install it. If the heater was much older, i would probably say to just buy a new heater. The exchanger usually run about half the price of a new heater.
May 18, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Recently I put a new heat exchanger on this H400 hayward heater. Went back out to check on it and the lights were not on anymore. So I checked the hi limit and replaced it and the heater worked agian. Went...
High limits are safty switches to keep the heater from over heating and runing your new exchanger. you will need to check the by-pass inside the water manifold. It could be the problem but hook up the limits in the mean time. As you are aware at this time the exchanger is your most expensive heater part you can buy.
Mar 22, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have a hayward H200 series heater and th eheat exchanger is leaking. I have pulled the heat exchanger out and cant see anything visible it is probably leaking inthe area covered by the fins. I have...
You need to buy the whole unit as these are pressed in place together. If you have a leak it is most likly due to chemical damage and goes further. So at the least you will need an exchanger. I will usually try to get people to go with a new heater if it is more than a couple of years old due to cost and hidden damage that can only come out after you install a new exchanger. Sorry for the bad news.
Mar 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400iDL2 pool heater burned up after only 3 seasons!
I dont know about your particular model. I do manage two Hayward 380,000 pool heaters that are natural gas fired and I have never had this problem you describe.
I also manage another dozen or so assorted other gas and propane devides. One propane device sooted so bad we had to discard it. It did this, according to the propane tech, because it couldn't breathe - there were louver type vents on the door that leads directly outside. He did, however, find a ruptured diaphram in the regulator and he replaced it. Hmmmmmm, couldn't breathe eh????
I'm not too surprised at the repair cost you cite. The exchanger is of course copper and there is the labor involved and lots of it. The age of your unit at this point is not relavent. What you do need to determine is why the unit sooted up like this. If you are gas fired, you know this is considered a clean fuel (compared to all others except electricity). What ever caused it must be repaired or you will be looking at another sooted up problem and repair ... and it will not be in three years, it could be next week.
I hope you find some value to my comments . Thanks for posting this question at FixYa.com
Positive comments welcome
a
Nov 02, 2009 | Hayward H400idl2 400,000 Btu Low Nox...
Heat exchanger knocking there is plenty of water going in and out of the heater but not enough going into tjhe heat exchanger It is for a spa the model # h100id and I don"t think it is a scaling problem ...
If the heat exchanger is not scaled up, it's probably the thermal governor. You should be able to unthread it from the inlet/outlet header and thread a new one in easily.
Oct 23, 2009 | Pool & Spa
Heater not working
yor heater has 3 high limits and a flame rollout switch(aka thermal fuse). be advised that bypassing safetys is not recommended and is dangerous.these component failures are symptoms. we need to find causes.if limits are failing look at sooted or possibly a nest on your heat exchanger. if its a flame rollout problem look at obstructed burner or oriface.
Jun 22, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
401 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
