Question about KEF Audio Q55 Speaker
Trying to hook up my Kef Q55 speakers for the first time and just not sure how to best wire the inputs as there are two red and two black on the back. Can someone explain how these work and how to best set them up? Thanks, CadillakJak
SOURCE: blown kef q55.2 tweeter, is replacement possible?
The tweater on my Q55.2 blew as well. I went into a shop in NYC and they tried to charge me $225 for a new tweater, so I took it home and called up Kef. They sent me out a new tweater for $35 and instructions on how to solder it in.
It took all of 10 mins to replace and they are working fine. I've never soldered anything before and it was simple.
Cheers
Martin
Posted on Sep 12, 2009
  • 57 Answers
SOURCE: I have 2 KEF Q35 speakers, i have them wired up as
These are quite common, and are just separate connection for each speaker in the enclosure. Just bridge the connections red to red and black to black with cable (use something like 5amp house wiring cable) and then connect your cable from your amplifier to one of the "ports" See http://www.brilliancehifi.co.uk/how-to-bi-wire-speakers.htm As you can see you could "biwire" if you wanted go further and improve the sound quality
Posted on Nov 24, 2009
  • 124 Answers
SOURCE: lost manuel
The Q55 is not a velodyne product
Posted on Dec 20, 2009
SOURCE: replacement of the tweeter of KEF Audio Q55
call kef. go to kef,com for the phone number. 28.02 plus vat per tweeter
Posted on Nov 11, 2011
facebook586
SOURCE: KEF Speaker Sticky
My Dad had the same problem. KEF admitted it was a paint problem and replaced the speakers.
Posted on Aug 20, 2012
Please send me a diagram of how the wiring is to be set up on the back of the speakers
The red connector on the speaker should be connected to the Pos.(+) connection on the Receiver/Amp. The Black to the Neg. (-) connection. ( for the proper speaker) Front Left, Front Right,etc. All, or most paired wire has either a black stripe,different shape on one,or different colour wire(silver/copper) So if you hook up the Blk striped or silver to the Neg.(black terminal) on the speaker, do so at the other end (receiver ) If both speakers aren't hooked up the same, they will work, but there won't be as much Bass because the speakers will be out of phase.(when one speaker cone is moving out,the other will be moving inward.
Dec 03, 2011 | KEF Audio Model Three Main / Stereo...
Morning I have a set of KEF Q 5 floor standing
I'd suspect a shorting voice coil in the woofer or a loose connection inside that vibrates and presents a wildly varying load.
Disconnect the bi-wiring jumpers and try driving each 'half' separately as a test for tripping the amp.
Jun 07, 2011 | KEF Audio Q55 Speaker
How do you connect the back cables so the sound will come out right
There are four posts - two black and two red. They should be connected together, as shown in the picture. If you are missing the brass straps, simply use wire to reconnect the posts, black-black and red-red.
Then it's a simple matter of connecting the red (+) amplifier output to one of the red terminals, and the black (-) amplifier terminal to the black terminal on the KEF.
The KEF terminals can be seperated if you wish to "biamp" or "biwire" these speakers. Each black/red pair is dedicated to either the bass or the treble. For higher fidelity, some listeners prefer to run seperate wires from a single amplifier channel to each individual speaker input.clmrt5000_5.jpg
Jan 19, 2011 | KEF Audio Q75 Speaker
Do LF and HF +/_ both be connected and if yes do they both go to speaker system A or separate to A and B on the amplifier.
From the factory, those are equipped with "jumpers", one for red-red and one for black-black. This allows for one speaker cable to power one speaker.
The jumpers can be removed, allowing for "bi-wiring", where you run two leads from a single amp channel to both inputs on each speaker. There's also "bi-amping", using a treble amp and a bass amp dedicated to each input.
If the jumpers are missing, you can use a short piece of stripped speaker wire to reconnect the upper and lower binding posts, just be sure to match colors.clmrt5000_0.jpg
Jan 10, 2011 | KEF Audio Q55 Speaker
Replacement of the tweeter of KEF Audio Q55 Speaker
Sep 27, 2010 | KEF Audio Q55 Speaker
Can you please tell me how to connect my kef psw
If your amp has a "sub out" jack, that's the best way to hook up this sub. You'll just need a single RCA (also called "phono") cable. Connect it to the Left input on the sub, which should also be marked as "mono"
If your amp just has speaker-level outputs, then connect the left and right main speakers from your amp to the sub's high-level inputs, and then run wires from the sub's high-level outputs to your speakers.
If you're running a surround-sound setup, use the front-left and front-right speakers for this hookup.
If this helps, be sure to hit the "thumbs-up" button for me!
If not, post back with the "Add comment" and I'll do my best to answer any questions you've got.
Jan 23, 2010 | Panasonic Audio Players & Recorders
I have 2 KEF Q35 speakers, i have them wired up as normal on the outside ports, but there are another set of wiring ports labelled HF (one positive one negative) what are these for? please help!!
Nov 24, 2009 | KEF Audio Q35 Speaker
Cant connect my q35 speaker, help please!! Theres 4 connections??
Hi, They should have a gold bar "jumper"between the two black/and the two red connectors. If not, it is missing,but the reason for that is you can use seperate amps for the woofer and the tweeter/mid.Called "Bi-amping."You can just use a extra wire to connect both inputs together. Black to black and red to red.
Oct 30, 2009 | KEF Audio Q35 Speaker
Blown kef q55.2 tweeter, is replacement possible?
Cheers
Martin
Mar 24, 2009 | KEF Audio Q55 Speaker
Lost manuel
Nov 17, 2008 | Velodyne CT-80 Subwoofer
KEF Audio Q55 Speaker Logo
118 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
shaqsatin
Level 1 Expert
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
