Question about Garden
Where to find serial number on a roll under 22 ton air hydraulic jack?
  • 8,197 Answers
The serial # is stamped on the jack before they paint it. It will be on the under side of the hydraulic part of the jack.
Posted on May 29, 2010
Hydraulic jack manuals
Look for a rubber or plastic grommet on the cylinder in the jack. That is the fill hole.
Aug 03, 2014 | Hein-Werner Hein Werner HW93642 2 ton...
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
What is a jack lift?
"A jack lift is a mechanical device used as a lifting device to lift heavy loads or apply great forces. Jacks employ a screw thread or hydraulic cylinder to apply very high linear forces.
A mechanical jack is a device which lifts heavy equipment. The most common form is a car jack, floor jack or garage jack which lifts vehicles so that maintenance can be performed.
More powerful jacks use hydraulic power to provide more lift over greater distances. Mechanical jacks are usually rated for a maximum lifting capacity (for example, 1.5 tons or 3 tons)." (Wikipedia)
Oct 07, 2013 | Hoisting
How does a floor jack work
Place jack under what you want lifted and close valve and put rod in jacker and jack up till your height is good,to let down turn valve counterclock wise.
Sep 13, 2012 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
How do you fill a ac delco hydraulic 3 ton floor jack model 34123 with hydraulic fluid
DONT KNOW WHO BUILT THIS JACK- AC DELCO JUST PUT STICKERS ON IT. TYPICALLY YOU REMOVE A PLASTIC SCREW IN PLUG OR A POP IN RUBBER STOPPER FROM THE TOPSIDE OF THE CYLINDER. WITH THE JACK ALL THE DOWN, FILL IT COMPLETELY UP AND IT SHOULD WORK. SOMETIMES THEY GET AIR IN THEM - JUST LEAVE THE PLUG OUT AND JACK IT UP A FEW TIMES, THEN INSERT PLUG. USUALLY 10 WEIGHT HYD OIL. OR "JACK OIL" AT THE STORE.
Mar 26, 2009 | Plumbing
Hi i have a 3 ton sears floor jack i can not
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Gary
Mar 01, 2009 | Plumbing
Hydraulic jack will not lower
hs it been overfilled? I sugest removin all the oil. lowering the jack, then re-filling withoil with the jack in the closed possition.
Feb 12, 2009 | RTO 20 Ton Air / Hydraulic Bottle Jack
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
