Question about Bunn NHB Coffee Maker
I have a Bunn coffeemaker and it is not that old. It leaks from the bottom when you fill it with fresh water for a new pot of coffee. The number is NHB code date is 204305. Do you have any ideas?
  • 189 Answers
The brewer probably has a bad seal or gasket. By the date code, your machine is 5 years old. If you call Bunn Customer Service they will be able to offer you an exchange of your old brewer for a new one at a reduced price.
Posted on Jun 02, 2010
My Bunn 10 Cup home Coffee Brewer Is Not Heating My Coffee Anymore
I would check your electrical supply. Plug in a hair dryer where the coffeemaker was plugged in and see if it works. If it doesn't there is probably nothing wrong with the coffeemaker.
May 27, 2014 | Bunn 10 Cup Home Coffee Brewer
Bunn automatic coffeemaker leaks water after making a pot
Tank and tank components should be delimed regularly
depending on local water conditions. Excessive mineral build-up
on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
Hot water leaks out the bottom when filling resevior with water of my Bunn coffeemaker GR10-B
If you will call 800-352-2866 with the model and date code and we will be able to help you resolve your issue.
Jul 01, 2010 | Bunn GR10 Coffee Maker
Coffee has a greasy taste
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Aug 09, 2009 | Bunn VPR Coffee Maker
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
We find water under the coffeemaker in the morning.
Sounds like a leaking water pipe from the water source, unless you have a over temp heater and this results in steam and dripping.
Mar 30, 2009 | Bunn VPR Coffee Maker
Bad tasting coffee
you can always clean a coffeemaker with vinegar, but always pour in cold, so you can do it twice or more, but dont re-use the stuff you just used, wait till it's cold or just use some other.after use clean by let water through 2 or 3 times, (also only cold water)
Jan 28, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn Coffee machine only makes 1/2 pot
What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Empty bunn coffeemaker
The easiest way to empty these brewers is to turn them upside down over the sink. Turn it on it's side, always keeping the fill hole down toward the sink, and keep on going until you have the unit completely upside down. If there is a push switch under the lid to stop water from going into the pot until the lid is closed, you will have to keep this pushed in until the unit is empty
May 30, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Bunn NHB Coffee Maker Logo
686 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
