Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Cant get the salt water pump started
It starts at 88 i tried holding the buttons down at the same time until it beeps but it just keeps beeping and stays at 88
Hold the left button until it beeps. Hold the right button until it beeps. You should see flashing 00. Set the time by moving the right button. Then hold down the left button for a long beep. Then hold down the right button for a long beep.
Posted on May 30, 2010
  • 1 more comment
  • mccreas916 Jun 26, 2011
    I am having a very similar issue to this. I can press my left arrow and it beeps once, but when I move to the right arrow, it makes a continuous triple beeping noise. (beepbeepbeep/beepbeepbeep) but the 00 code will not appear. The triple beep noise stops immediately when I release the right arrow. I am suspecting that the keypad is damaged. What do you think?
  • jtlivvy21 Jul 11, 2011
    I am having the exact same issue. Left arrow beeps once, but right arrow makes continuous beeping. When I just leave it on and don't touch the keypad, it's just a slow beep every five seconds or so. Any more ideas out there?
  • babbzzz633
    babbzzz633 Jun 08, 2013
    Same problem here 1 beep but down button gives me multiple beeps is there any other way to set it?
I have a salt water pump 8110. It won't go pass start up and when I push the left button it just keeps beeping. It will not let me unlock the keys to set timer. I have already unplugged for 10mins....
Okay... Let's do this step by step...
1st... Press the down arrow button until you hear the beep and let it go quickly..
2nd ..Press the up arrow button until you hear the beep and let go quickly..
At this point, the LED reading should be blinking 00.. If it is, you have unlocked the keys and you can now press the up arrow button to increase the timer to 01, 02 and up to 12. Note: To adjust the time, press the up arrow button in short intervals, do not hold down the button. It tends not to adjust if you hold down the button longer than 1 sec.. I hope this helps and it not a bad unit.. If it did, please post a comment and rate.. really appreciated...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
My intex saltwater pump reads 88 and when I hit the arrows it continuously beeps without ever resetting to 0. I unplugged overnight and still doesn't work.
This thing is very sensitive. If you dont get the timing just right or in the right order that often happens.When it happens turn it off for a few seconds then try again. The book says hold the down button down for 5 seconds until you hear one beep, then up button for 5 seconds till you hear another beep. I find that 5 seconds sometimes isnt long enough and sometimes to long. Like I said, it is quite touchy. After two years still have it happen sometimes. P.S. Make sure the pump is running and water is flowing when you try it.
May 07, 2011 | Intex Automatic Salt Water System for ...
Error mess 88 will not go off. It beeps repeatedly when I hold down the up arrow and does nothing when I push the down arrow
Hold the down arrow until it beeps, then hold the up arrow until it beeps, then press the up arrow until desired hours and then press and hold down arrow til beep, hold and press up arrow til beep. The green light should come on in 2-10 mins
Jul 12, 2010 | Intex Automatic Salt Water System for ...
I just connected my sale water pump and can not remember how to program it. 88 is on the display and when i press on the up and down button it just beeps? help. di
start by holding down arrow until it beeps
now hold up arrow ti'll it beeps
now push up arrow with quick pushes to set hours
now your choice to lock it
either leave it alone for 2-10 minutes and it will lock and go to seccond green light
or repeat step 1 & 2 and still wait 2-10 minutes for the chlorine light
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 29, 2010 | Intex Automatic Salt Water System for ...
I have an intex salt water filter, what is code 88
It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
Jun 03, 2010 | Intex 2000 GPH Salt Water Filtration Pump...
How do i set my salt water generator?
Hold the down button until it beeps, then hold the up button until it beeps. Now its ready to be set. push the up button to the desired amt of time you want the system to run. Once you have the time set, hold the down button until it beeps then the up button until it beeps. Now its locked and ready to go!
May 26, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
I can't get the (Intex) salt generator to time set. It just stays on 88.
Did you attempt to unlock the keypad before trying to set the time? In case you didn't, these would be the proper steps:
Unlock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep.
Set the number of hours you want it to run by adjusting the time display using the "up arrow" or "down arrow" until you have the correct number of hours.
After setting the time re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep. Several minutes later the Green LED should come on indicating the cycle has started.
Jul 06, 2009 | Intex Automatic Salt Water System for ...
Intex pool chlorinator trouble with unlocking mechanism
do not get frustrated with the long phone call.
Get your receipt ready and you could have a new filter in a week
CALL THEM BACK
They are good about these things
Mine arrived in 5 days no questions asked. I didnt even have to send the old one back
Keep as many parts from the old as you can especially the electro cell that is 200 bucks by itself
Jun 27, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
354 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
