Question about Dell 946 All-In-One InkJet Printer
Printer not working. How can I reinstall software
How can i reinstal software for dell printer 946
Posted on Jun 08, 2010
Nothing is happening when i tell it to print.. when i go to uninstall the software ( so I can reinstall) it says i have to wait because printer is in use. Please advise
Hi ericsworld9
Unplug usb and power cables from printer . Make a restart of the computer . Delete and reinstall printer software . You will maybe need to reboot before reinstalling . Reconnect the cables and press start button of printer . It should work .
Best regards ,
fanaudi .
Sep 08, 2011 | Lexmark X5470 All-In-One InkJet Printer
After reinstalling software I get this error messages everytime I try to print. "Color table is missing. You must uninstall and reinstall the printer software." Have reinstalled about 10 times now with...
The error happens when the Lexmark Printer Driver v2.2 Software Update is installed first before the printer driver from the installation disk or web download. You can easily fix the issue by following the instructions from the Lexmark website at http://bit.ly/bYf2QI. If you need further assistance, contact Lexmark technical support. Thanks.
Oct 15, 2010 | Lexmark X4550 Multifunction Wireless Color...
Scanner won't stay installed
When you install the printer software is it installed properly? if the printer is installed properly then you will do need to do the same step. First, uninstall the printer software by going to control panel > add/remove programs and then uninstall all the printer software. then go to control panel > printer and faxes if printer is present in the printer and faxes delete the printer. Restart the computer. Before reinstalling the printer software turn off your firewall, anti-virus, spyware if you have any. Then reinstall the printer. Try to scan again. if it works then try to restart your computer and scan again. it should work
Oct 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
I cannot access the print preview screen. Printer is Epson Stylus Photo 1280, OS is Vista
Best bet is to reinstall the software and drivers.
The printer is rated to work with vista.
Usually when something doesn't work on the software end a bad installation is the cause.
Try to uninstall and reinstall the drivers.
Be sure that the device is not connected to the computer until the software prompts you to plug it in
Sep 27, 2009 | Epson Stylus Photo 1280 InkJet Printer
Brother dcp 8060 reinstall paper tray error message
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function CenterĀ® DCP-8060...
LexmarkZ600 will not print I put in new ink cartridges.
Try first unplugging power cord, pulling out cartridges, and putting them back.
Ensure you removed the cellotape strip from new cartridges, and that cartridges are properly installed.
Ensure that the printer is set as default printer in Windows.
Print a test page from control panel>>printers>>properties.
If all the above does not work, try a replacement USB cable, just in case, then proceed reinstalling the driver software. Follow the method below to reinstall software:
To reinstall the software you can use the disk that came with the printer, or download the driver software:
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthe file, double click on the file , then if you getintroubles,followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
None : if you have Vista, many old models will not work unless they are Vista compatible.
Oct 28, 2008 | Lexmark Office Equipment & Supplies
My device would not print photos so i unistalled and cannot reinstall software
Unplug printer usb.
Remove printer from installed printers, in control panel.
Reinstall software from disk.
If disk is scratched or not working, or if you do not have disk download software from HP
Sep 07, 2008 | HP Office Equipment & Supplies
Dell 946 All-In-One InkJet Printer Logo
121 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
