Question about ASUS Eee PC 900 PC Notebook
The function key is stuck on and the strat menu
I have tried all the function keys, nothing works. Now the start menu keeps coming up
  • 35 Answers
What you need to do is to get a skinny flat tip screw driver and pop it back into position. But be careful though because if you pop it off you might not be able to get it back on. I have popped my f8 key on my laptop and haven't got it back on due to some tiny plastic pieces that if you don't have on correctly you won't be able to pop it back on. If you bought the laptop recently you may be able to go where you bought it and see if they can fix it for you.
Posted on May 29, 2010
Where is the wireless button located on bytespeed PC
Check the function keys (F1, F2, F3, etc) for a "wireless" icon. Then when you have found it, hold the "Fn" key (lower left hand side of the keyboard) first and try toggling the function key until a menu comes up or the wireless starts to work.
Sep 17, 2014 | Computers & Internet
HOW TO RESET LAMP HOUR OF LG PROJECTOR MODEL BX-401C
Try this, it works on older LG TV models:
Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
Press Exit on the remote to come out of the menus.
Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
Aug 31, 2014 | Office Equipment & Supplies
The jkl are coming up as number,cant seen to unlock it or how!
MORE DETAILS!
I really need to know operating system and Keyboard make and maybe model to give you a definite answer. I'll do my best though.
1.It could possibly be that your "function" key is stuck.
This key is usually blue or yellow and has "Fn" on it. Look on your keyboard and see if you can find a "Fn" key. If you find it try hitting it a few times and see if it works to change the letters back to numbers and vice versa. If there is no response than it could be stuck Internally.
2. To see if that is the problem try hitting some other keys and see if they come up right or are displaying their secondary "function"
3.If all other keys except jkluio are working normal than then next i would try the "num-lock" or any other "lock" buttons located on your keyboard. These are usually located at the top right hand corner above the number pad or to the right of the "backspace"
4.If that does not work than it is a setting in your computer and you need to restore your settings to default.
a)Hit start and go to the control panel
b)once in control panel select "devices and printers" or "printers and hardware" depending on your OS
c)Once in that menu you should see an icon that says "Keyboard"
Click on that...
d) This menu will vary a ton between different OS's and keyboards and drivers so you need to look around and try to set to default. There should be properties and settings you can adjust. Also a "troubleshooting" option is worth clicking on.
5.If your still not fixed, look in the keyboard menu in the control panel and click on the "Drivers" tab. In this tab you will see options to "Update" the driver and "Roll-Back" the driver. Try each of these once starting with "roll-back"
If NONE of these steps has resolved you issue than i would say the keyboard is broke and to get a new one...
Hope this helps GOOD LUCK!!!!
Jan 05, 2013 | Acer Aspire 5720 6497 Laptop
I tryed starting my 2006 cadillac cts this morning and the key turns over and the car wont start. also as i bring the key back the key wont come out of the ignition. now its stuck. my key fab does not...
try removing your key fob and replacing the battery .it sounds like its a security issue and the body control has locked you out and is keeping the key too.replacing the battery in the key fob should restore all.if not you will need a body control module and has to be programmed by a dealer.
Sep 03, 2011 | Cadillac CTS Cars & Trucks
Just say unable to clean 35. nothing is working
Hi there you can try this not know if it will work for you but it works with some brother printers
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times until the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. Press the stop/exit key to return to the initial stage of the maintenance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2010 | Brother MFC 490cw Color Inkjet...
Pass key fault light comes on and car want strat.
i had the same prob in my 94 the ignition cylinder is bad change the ignition and i swear it will work perfect
Jul 03, 2009 | 1995 Chevrolet Caprice Classic
My ipod got stuck totally .does not function at all . it almost no keys are working.. nothing works .
Try reseting it. Hold down the "Menu" button and the middle button for about 7-8 seconds. The apple logo should appear, then just wait about 5-6 seconds for your ipod to start up again.
Hope this helps!
Jun 09, 2009 | Apple iPod Photo MP3 Player
Caddy Deville wont start
Check the gear selector switch. You may need a Chilton's book to find it. Try starting in neutral.
May 04, 2009 | Dell Inspiron 2650 Notebook
Keypad not functioning properly...
Check to see if your shift, control, alt, or other modifier keys are stuck on your keyboard. These can cause your keyboard to act erratically. Also, if this is a wireless keyboard, you may need to change the batteries, as this can also cause a keyboard to act erratically.
May 14, 2008 | Acer Computers & Internet
Start up menu
I know nothing about this machine in particular but immediately when the computer beeps... Generally the "delete" key gets you into the bios menu. If not that, then its almost always a function key "F1"-"F12" Just try running your finger down and back the function row as it boots if "DEL" fails Windows' boot menu comes up when you hit "f8" repeatedly before the windows logo appears. For older Windows versions use the left shift key and hold it just before and during the windows logo. Give it a try!
Aug 28, 2007 | E-Machines etower 466is PC Desktop
ASUS Eee PC 900  PC Notebook Logo
83 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
