Question about Canon PIXMA MP160 All-In-One InkJet Printer
Cannon pixma mp 160 printer grabs mulitiple sheets of paper
    Sergeant:
  • 284 Answers
Either is the Drive Assy or Pick up roller broken.
Posted on May 30, 2010
Saya punya masalah print cannon pixma MP 287 kertas gak bisa masuk pada saat diprint, kalau bisa kertasnya tergulung
I have a problem cannon Pixma MP 287 print paper can not enter when printed , if the paper can be rolled up
Dec 20, 2012 | Canon LASER SHOT LBP-2900 Printer
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a cannon mp 240 bought it 7 months ago have barely used it, just purchased 1st set of ink cartriges. have printed maybe 4 pages since replacing.. Now says out of paper, wont feed sheets in. help!!
Check the rollers that feed the printer paper through. Use compressed air to clean out the printer and rubbing alcohol on the rollers once you clean them. If the rollers aren't grabbing the paper, then maybe a gear is not working properly.
Canon offers a one year warranty, take the printer in and get them to service it instead of trying to fix the problem yourself.
Sep 01, 2009 | Office Equipment & Supplies
Under one year old pixma mp150 all in one/ changed ink cartridges/error code E2 / saying no paper ????
I have had a MP 150 Cannon Printer with a E3 paper jam code..when NO visable paper jam is present ! Your No paper problem may be as a result of similar issue due to a small piece of paper stuck in the roller assembly out of sight. TRY this, Turn printer off wait (10 seconds) or more then turn printer back ON and listen for roller assembly to turn the ROLLERS and then FORCE FEED
a sheet of paper into rollers until it PULLS paper through and SEE if any scrap of paper comes out with the sheet !! If this works you should see that it clears the code. and resets your printer.
Let me know if this works. Phil at palcando@yahoo.com
GOOD LUCK !
May 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
Mar 11, 2009 | Canon Office Equipment & Supplies
Grab paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not feed paper / message E2 ...cannon pixma mp 160
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, for others its taken a few attempts and then worked..
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. hope this helps, let me know how you get on. Garty
May 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Cannon MP 160 Printer
you need a bluetooth print server to plug into the printer
Feb 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
