Question about Toro Lawn Mower With Toro Power Tools
How do i adjust blade belt/clutch on Toro 20622 mower
How do i adjust belt/clutch on Toro 20622 mower (1986 - 8000001+ serial number). When I encounter heavier grass, the engine continues at proper rpm but the blade slows or stops.
3 Suggested Answers
  • 60 Answers
SOURCE: My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Posted on Jun 24, 2009
USMC ETECH
  • 60 Answers
SOURCE: have a toro 217d 1986 model with a 30562 62inch
THIS IS THE WEBSITE FOR THE MANUAL. SO FAR THIS IS THE ONLY SITE I HAVE FOUND WITH THE INFORMATION.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#manualsResultPage
I HOPE THIS HELPS IF NOT PLEASE LET ME KNOW AND I WILL FIND SOMETHING BETTER.
Posted on Feb 23, 2010
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
Replac drive belt 20068 personal pace with blade clutch
One belt runs your clutch the other runs your drive. there is a very small but thick belt which runs the clutch. longer belt for drive system
Jul 28, 2014 | Toro Garden
How do i adjust the clutch on a 12/32 toro ride on lawn mower model 56175
You need to adjust the belt keeper until it almost touches the belt. The pulley is not good enough for its purpose. The lips are to short for its positioning and purpose. But if u get the keeper right next to it it will eliminate the space needed for the belt to drop down. I fixes more than 100 like this.
May 09, 2014 | Toro Garden
How to replace drive belt on toro recycler
First thing you need to do remove spark plug wire.. Then I would go to the website for Toro have the serial number ready there you will see the full picture of the way it is then go from there that's the best way with out seeing it. Good luck
Sep 15, 2012 | Toro Lawn Mower With Toro Power Tools
How do I remove the blade of my SR4
This is from the Toro owners manual for SR4 euper recycler model 20058 serial number 250003464
The steps and picture are on page 18 of the manual 3352-864[1].pdf
You can enter those numbers on this page for a manual:
https://lookup3.toro.com/request/request.cfm
1. Disconnect the spark plug wire from the spark
plug. Refer to Preparing for Maintenance
2. Tip the mower onto its side with the air filter up.
3. Remove the
2 blade nuts (A)
and the
stiffener (B).
4. Remove the
blade (C).
5. Install the blade and the stiffener that you
removed in steps 3 and 4.
6. Install the blade bolts and torque them to 15 to
27 ft-lb (20 to 37 N?m).
The replacement blade part number is:
108-3762-03 (google / net search)
Thanks for choosing FixYa,
Kelly
May 20, 2011 | Toro Power Lawn Mower
I have a 1988 Model 26624, 21" Key-Lectric mower. I've noticed over a period of time that the mower blade slows considerably when cutting the lawn. At first, I thought it may be grass accumulation under...
Yes, it sounds like you need to adjust the blade brake clutch (BBC). I have a PDF service manual that explains it. If you post your email address I can upload it to you. Here's an excerpt from the manual:
BBC
BBC Adjusting the Blade Brake
1. Stop the engine. Pull the wire off the spark plug.
2. Remove the two screws securing the screen
panel to the top of the mower housing as shown
in Figure 22. Remove the panel. (The panel they're
referring to is the red screen between the motor
and handle.)
3. Move the control bar down and lift up against the
handle. With the control bar against the handle,
measure the spring length (L) at the front of the
spring as shown in Figure 26.
4. If the spring dimension is greater than 32 mm
(1-1/4") an adjustment is needed.
5. To adjust, loosen the bottom jam nut on the blade
brake cable as shown in Figure 27. Adjust the top
jam nut until spring dimension is as near as
possible to nut; not less than 25 mm (1") See
note below.
NOTE: Adjusting the top jam nut too high can
cause the cable end to crush the plastic fitting
when the control bar is moved up against the
handle. If the spring cannot be adjusted to less
than 32 mm (1-1/4") before the cable end
contacts the plastic fitting, the clutch belt is worn
out and should be replaced. After replacing the
belt, adjust the cable per the above procedure.
NOTE: 1990 and newer models are equipped
with finger tip adjusters that do not require tools.
Use the same adjustment criteria on these
cables.
Sep 18, 2010 | Toro Lawn Mower With Toro Power Tools
We have Toro Lwa 100 Lawn Mower Model #26623. Power engaged, start mowing but lawn mower will not cut grass. You have to stop and let it rev up again to cut more grass.
This 1991-92 model is equipped with a blade brake clutch. When the blade slows down this means the belt is slipping. This slipping can be caused from a few different things.
Try adjusting the blade cable on the upper handle. this unit has an adjustable section. make sure the cable is not so tight that you snap it.
2 --A sticky pivot point under the belt cover
The belt cover in the back builds up with dirt and debris. Make sude it is clean under the cover and all of the pivots move freely. ( do this with the engine off)
3 --A sticky belt tensioner under the deck cover
The underside of this machine has a metal cover to protect the belts. Remove it and check that the blade belt idler arm is not frozen in place. this will cause the belt not to enguage all the way.
4 --A worn belt or belt pulley
The large flywheel and pulley can wear. Check this if the belt looks good.
This is all there is to the machine BBC system.
I hope this helps.
Get parts and more diagrams at a Master Toro Dealer like www.arcolawn.com
Jun 06, 2010 | Toro Lawn Mower With Toro Power Tools
Blade won't engage - mower starts and propells itself, but when the yellow arm is pulled and lowered to engage the blade, nothing happens.
The blade is probably belt driven, and the belt is either broken, need adjusting, worn that bad, or there is a pulley problem. Get it in the air and check that the belt tightens. It will not be completely tight, there should be a tiny bit of play when engaged.
Mar 29, 2010 | Toro Lawn Mower With Toro Power Tools
How do I change drive belt on my toro 22187
This appears to be a BBC Blade Brake Clutch. This is kinda hard to describe. Its best you take it to a dealer.
There are two belts both are drive. Blade drive and ground drive. The are accessed from the bottom of the machine.U must remove the blade ,then the belt covers. From that point its pretty much self-explanitory. Toro provides an online manual for this.
Sep 17, 2009 | Garden
No drive
Hello orlywooldrid:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers (20622) and Click Search. Now Select View Assembly Drawings for your Year Model.
Everything you Asked is at the Above Site Addy.
Parts can Also be Purchased from this Site Addy;
http://www.outdoordistributors.com/
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 08, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
781 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
