Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Slow water flow from the water dispenser
How do I get the water to run out of the water dispenser more quickly. It is so slow I just use the tap water after I get the ice.
    Novelist:
  • 77 Answers
If it was fast at one point there are a couple of things that come to mind. Make sure your water line is not kinked at any point behind the frig. Also, when was the last time you changed your filter? Dirty water filters can cause low water pressure. Let me know if I can help further, good luck! :D
Posted on May 30, 2010
Water dispenser is not working
The water flow needs to be checked,if the flow of water is very slow or no water is flowing then water dispenser will not dispense water.But water flow is checked ok then other possibilities like water valve and water line needs to be inspected.For more details.Click the link below:---
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
This should help.Thanks.Helpmech.
Oct 20, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Lg 27.7 w ice maker water dispenser has little 'water pressure slow flow on water dispensing
If your ice maker kit has a piercing nozzle you would want to change that cause they build up water deposits very quickly
Dec 15, 2010 | LG Refrigerators
Water dispenser leaking dispenses ok, but does not always shut off fully resulting in a slow drip. Like a dripping tap might be just a washer?
you have a faulty water valved solenoid. when you actuate the water lever, the solenoid opens, to allow water flow, then closes to stop it. When you continue to get a dripping before or after, its because the solenoid is not closing completely. Only resolution is to replace the water valve.
Mar 26, 2010 | Freezers
Water dispenser is just a trickle
the biggest culprit for slow water dispensing aside from the filter is the water supply its self. check to make sure the water line isnt kinked behind the refrig, if thats ok then disconnect the water line from the refrig and run water into a bucket and observe your water flow. good water pressure would basicly fill a 2 gallon bucket in less than a minute. much less than that can cause problems. hope that helps peyton
Jan 29, 2009 | KitchenAid KSRA25CNSS Side by Side...
Water leaks out of the automatic dispenser
Slow down the water flow from the tap( Turn the tap on by about 1 or 2 turns). I have the same problem. the dispenser system cann't handle the volume supplied by the house system.
Sep 30, 2008 | Maytag MAH8700A Front Load Washer
Water dispenser is working very slow the water is flowin very slow.
is the s water holder frozen?
Look behind the lower left prodcue box
if not it could be the despenser valve not
opening all the way
Is the ice maker working OK?
Aug 04, 2008 | LG 22.4 cu.ft. French Door with External...
Slow water dispener
there s a motor present for the working of the water dispenser whose rpm would be slow due to which the water dispenser is slow so change tat motor or repair it and then use it after tat it will work properly
Jul 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Apr 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
260 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
