Question about Canon Pixma iP6600D InkJet Photo Printer
Error code 5100 on my Pixma iP6600D.
I have changed the yellow colour cartridge and Error 5100 appears. Printer makes grinding noise when I attempt to start it.
  • 1 more comment
  • Printerdog Apr 08, 2008
  • JAN88 Apr 09, 2008
    I HAVE THE SAME PROBLEM. CANON TECH SUPPORT TOLD ME TO REMOVE ALL CARTRIDGES AND THE TUB THAT THEY ALL FIT IN.
    I DID PRINTED A FEW PICTURES AND ERROR COMES BACK ON.
    REMOVED SEVERAL TIMES AND STILL COMES UP. I HAVE A BUNCH OF PICTURES TO PRINT. I NEED HELP!!!!
  • paulchap May 20, 2008
    I replaced a cartridge, was greeted with "Error Code 5100" on printer screen and a noise as if the printer was handling a bucketload of sharp gravel instead of a sheet of paper...
    Online "help" that I've looked at is unintelligible to this tech-challenged user...
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Posted on Sep 04, 2008
Error code 5100 i have turned off machine, unplugged at electrical source. After 30 min replugged in to electrical source, turned on printer. Pressed print button. Machine processes for a few minutes...
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 11, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Canon PIXMA MP180 All-I-One It shows check printer 5100 erros
error 5100, this error appears and the problem is your cartridge, please double check your cartridge is connect properly and if it still have the errors change another cartridge, a new one...
Jun 22, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon pexma ip6600d photo printer
my friend who is a computor t echnician came to see if he could fix it and he did. he had to go into my pixma ip6600d photo printer from the back of it and tilt it , he then discovered one of the inks were not fully in and thats why it wouldn,t move, he then pushed down on top of the 6inks with a pencil and the inks were all even and they started moving freely again. I hope this works for others as it is a great photo printer.
Nov 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D - ink problems
Use original cartridges. Generic or refilled cartridges tend to cause these problems.
Oct 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D error code
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
Oct 06, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Cannot get Canon PIXMA MP 150 to work at all
salve la mia mi canon mp 150 lo scanner non funziona e mi da errore code 2,250,0
Apr 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printer wont print
Service error may mean- ink overflow chamber needs attention Check Canon Technical Support or go to www.fixyourprinter.com
Jun 06, 2007 | Canon PIXMA iP2000 InkJet Printer
Canon MP170
primeramente me salio 5100 pero luego paso a 6000 no se lo que puede pasar ya que no se mueven los cartuchos y no hace el reseteo cuando la enciendo y solamente me sale COMPRUEBE IMPRESORA Y SALE 6000 ERROR. en espera me sean indicados los problemas que se puedan subsanar un saludfo
Feb 28, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
220 people viewed this question
old marine
old marine
