Something unexpected surprise fashion
hello everyone,im wholesale supplier online
Believe you will love it.
very good shopping web.
our website: { w w w - ( jordanforworld ) - c o m }
dear . you have water mix with diesel . dont start again . replace diesel filter connect fuel from out side , if you find injector cleaner try use it , after replace fuel filter try to put 50mm engine oil in fuel line . for lubricate and remove rusty.
U paid 290 euros and they did not fix it. I would go back and insist that either they fix it or return my Euros so I could take it to a competent mechanic.
i do not know but give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
HAVE THE SECONDARY AIR INJECTION SYSTEM CHECKED OUT.TO MAKE SURE ITS ELECTRIC MOTOR PUMP ASSEMBLY VACUUM VALVE SOLENOID COMBINATION AIR SHUT OFF CHECK VALVE AND TUBING IS INJECTING FRESH AIR TO EXHAUST MANIFOLD.CHECK IT FUSE AND RELAY.GLOW PLUG LIGHT.COULD MEAN A FAULTY GLOW PLUG FUSE OR RELAY PROBLEMS.
Sometimes the issue is with the mechanical vacuum pump off to the side of the ABS/ESP module. It looks like a round silver canister. This issue is all over Google with many possibilities but the one I copied is most common.
ELECTRONIC STABILITY PROGRAM ( ESP) LIGHT FLASHES TO INDICATE UNSTABLE DRIVING CONDITIONS....WHICH WILL ALSO COME ON IF YOUR ENGINE IS MISFIRES.. CHECK THE COILS AND SPARK PLUGS FIRST THEN GO FOR FUEL..INJECTORS...FUEL FILTER CHOKED..HOPE I WAS OF SOME HELP TO YOU..
