NEED TO TAKE THE OLD 7-9 INCH TV OUT OF THE OVERHEAD PANEL TO PUT THE CORD IN FROM A DIGITAL CONVERTER SO I CAN WATCH THE TV...FORD AERO CONVERSION, 1991
    Novelist:
  • 144 Answers
If the old TV works OK but won't receive channels after the change to digital your TV is still likely to be just fine..
The digital converter hooks directly to the Antenna and the output goes to where you disconnected the Antenna from on the TV. Actually getting the TV out of it's location in a Van conversion might be a very difficult project indeed. Often you need to remove the entire housing that surrounds the TV. Don't forget that there are wires hooked into that console so you need to disconnect them before you can remove it all the way. I suggest that you put a piece of masking tape on the wire as you are disconnecting it and write on the tape what the name of the location that you are disconnecting it from.
Posted on May 30, 2010
Testimonial: "I am into "very difficult to remove entire casing". Not that this 70 year young rascal of an old grandma has any techinical skills but as you suggested, very good at labelling removed parts. I have an electric screwdriver. Beware, Nana at work. Thank you so much. I am courageous but very careful around electric cables. By the time I am done only the tires on the van may be left!!!!"
Tip
GPU/CUDA Accelerated Video Converter for Home Server with Aunsoft Video...
Fast CUDA Video converter-Fast Converter for Home Sharing with CUDA Technology <br />Aunsoft Video Converter at Faster Speed with CUDA/GPU for Home Sharing <br /> <br />Good news for Windows users with NVIDIA CUDA graphic card for GPU acceleration. <br /><br />If you have GeForce GTX 570, Quadro FX3800, Quadro 2000, Quadro CX or the like, you may find the <b><a href="http://canon-videoconverter.com/2011/06/good-news-cudagpu-acceleration-for-home-serverplayer-support-in-aunsoft-video-converter/">CUDA/GPU Accelerated Video Transcoding</a></b> with Aunsoft Video Converter. Enough 3X faster or even 5X faster speed for conversion. <br /><br /><b>Quickly convert TiVo to MKV for home sharing.</b> <br />The *.tivo files could not play now home media players like PS3, Popcorn Hour, AC Ryan PlayOn. If you use Aunsoft Video Converter, just a few clicks will help you convert tivo to MKV for media player. It is easy to steam videos to TV for watching. <br /><br /><b>Put and play videos on mobile devices.</b> <br />Import your videos to Aunsoft Video Converter, and you will find it easy with the existing profiles like iPad 2, iPhone 4, Droid X, and Galaxy S. CUDA will be activated to speed up conversion. <br /><br />Hurry up to get the full use of your NVIDIA CUDA graphic for <b><a href="http://www.aunsoft.com/video-converter/">GPU acceleration with Aunsoft Video Converter</a></b>. It is compatible with Windows 7, Windows Vista and Windows XP. <br /><br /><b>Tips:</b> <br />Other sub-products from Aunsoft also support NVIDIA CUDA acceleration and iPad 2 profile.
on Jun 16, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Can I connect two tv to one television converter box to watch local channels
If neither TV has a digital TV tuner, you will only be able to watch one channel on both TVs with one converter box. You will also need some sort of RF repeater if you want the person in the second room to change the station without moving the box. You will need a splitter/amplifier connected to the converter box TV out. (I'll assume you are using the coax out.) If you will only watch one TV at a time, then use an A/B switch on the converter box TV out.
If one of the TVs has a digital tuner, put the splitter/amplifier between the antenna and the converter box and the TV with the digital tuner.
Note: amplifier/splitters and switches do fail. If you get a "no signal" message, take out the splitter and connect the converter box directly to the antenna or one of the TVs depending on your set up.
I hope this helps.
(I use an A/B switch between the antenna and the TV and converter box for feeding an old VCR/DVD recorder.)
Mar 08, 2013 | Televison & Video
We are in Ghana we need frequency and we update to get more channel
Your flat panel TV is probably factory set to receive ATSC signals (Hi-def DIGITAL TV), whereas
Ghana may not have converted from analog TV (NTSC) yet.
Digital TV's cannot receive analog signals. I'm just guessing about whether or not Ghana supports
Hi-Def broadcasts - you'll have to check with (any) TV channel in Ghana. The Analog-to-digital
conversion is an expensive one at the broadcast end, and may not have happened yet in Ghana.
The US conversion took place by FCC mandate June 12, 2009.
There are available $65 (USD) digital-to-analog converters, but what you may need is an
analog-to-digital converter, which doesn't exist. Your Flat-panel TV amy have to wait until Ghana
begins broadcasting a Hi-Def TV channel.
For a HD antenna, a regular old rabbit ear-type antenna will do.
Oct 15, 2010 | Televison & Video
2005 Conversion Van has TV What do I need to do to receive Signal
If the audiovox does not have digital capability you will need a converter. The converter "converts" the digital signal back to the old signal so that your tv will recognize and play it. Thanks for using fixya.
Mar 03, 2010 | Audiovox AVT1498 TV
Why does my digital TV image fall apart into pixels and the sound breaks up - when I switch the digital box to TV antenna, the reception is ok, just not so sharp as with digital conversion. Is it a problem...
Tries directly to a good antena,like outside antena.or a digital antena,no need for any box,new LCD Flat screen tv have an converter in side,no need the box help only old CRT tv have no converter board in side.
Oct 31, 2009 | LG 42LG50 42 in. LCD HDTV
I have a Sylvanis VCR/DVDcombo and a Standard TV.
The converter box receives hte digital signals and converts them into either channel 3 or 4, or into direct video (red,white,yel). The output of the converter box must go into the VCR input for recording to work. Before the conversion, the tuner of hte VCR would receive the RF signal the same as the TV. The tuner inside the VCR is an analog tuner not digital, so it needs the conversion too. Most converters will provide both the A/V signal (R/Wh/Y) and RF (coax connector).
Hope this helps,
Dan
Sep 30, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
Digital to analog converter box to tv/vcr combo
You will need a splitter and an rf modulator to do timed recording of programs. The instructions are on the dtv answers website, option # 2, record and watch a different channel. The recording is for the analog stations 1-24. You cannot record the higher stations. The items I purchased were a 3 way splitter $7 at local hardware store, an rf modulator $25 at Radio Shack. The other option was to get a cable box for the tv and record off of that at $6.95 a month or a DVR for $8.99 per month, all from comcast. The price that I paid for the items I needed would be repaid in 3 months if I were to go the comcast route. The conversion is nothing more than a money making scheme for them.
Mar 21, 2008 | Televison & Video
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
