Question about Ovens
Corning counterrange 3+1. Front right burner is not working. Is the part avaalable? Serial #2195202810
  • pinson4 May 31, 2010
    I'll let you know what happens.
    Genius:
  • 1,417 Answers
You can get you oven burner in the store (i mean the front right burner )
what you need to do while going to the store is to write down the serial number correctly
with little amount in any tech store around you
Thank you and thanks for using fixya.
Posted on May 29, 2010
Right front burner only works on hi setting model C97-440721
This is usually caused from a bad switch. I assume you have an electric range.
Mar 26, 2014 | Ovens
My magic chef rv range will not light the burners with the ignitor. I replaced the ignitor at the control due to the wire prong being broken off. It worked prior to the wire prong breaking off. What do...
hope this helps a little...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/15-104--/Magic-Chef-Stove-burner-won-t-light
Jan 14, 2018 | Magic Chef Ovens
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    I have a defective flame sensor on a duke oven, I need to know the best way to remove it to replace with a new one. It does not appeear there is enough room inside to access it.
    it does require removal of entire burner assembly. which is not all that hard to do but a bit time consuming. fittings for 2 burners and pilot must be disconnected and 3 screws on front of burner assembly. unit will then pull right out allowing access to flame sensor bulb. hope this helps!
    Apr 22, 2010 | Duke E101-G Gas Single Oven
    Front right side burner does not work.
    This is an easy repair. Just contact us at:
    http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct burner out to you right away.
    You will be cooking again in no time!
    Call us from 7 AM until 9 PM CST. Thanks, Ella
    Nov 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    The temperature control on the right front burner does not work. It is either full heat or no heat
    The burner control infinite switch is not working. You can replace it. Turn off breaker first and put in the new switch you buy from an appliance shop.
    Jul 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    My right front burner quit working, can I replace it?
    Hi, Could you get me a model # so I can look this up and give you instruction on how to change the burner
    Vic
    Need Manual For Electrolux Oven Model EOB 985GR
    Having trouble locating the correct model number. Look at following areas for the model number
    • Under Right Front Burner
    • Under Left Top Burner Front Or Rear
    • Under Main Top Left, Rear Or Center Front
    • Under Left Rear Or Right Front Element
    • On Nameplate Inside Burner Box
    • On Front On Burner Box Bottom
    • On Nameplate On Oven Door Liner
    • On Main Front Behind Oven Or Compartment Door
    • On Front, Center Bottom Of Burner Box
    • On Thermostat Cover Under Main Top
    • Let me know, Sea Breeze
    Mar 27, 2009 | Electrolux Ovens
    Front right burner on GE glass top range not working
    If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
    Feb 28, 2009 | GE Profile JKP18 Electric Single Oven
    My right front burner will not turn off on my electric stove top?
    Hello, the switch controls the element ,if the element is staying on replace the switch.Please note any electrical repairs should be performed by an authorized service technician. good luck
    Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovens Logo
    41 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
