Question about Sony Playstation 3 (PS3) Console
Game will not come on. In the off position the red light blinks.tap the on button the red light stays on(like it should in the off position). Tap to turn on the light turns green,blinks 2 to 3 times, then shuts off. Back to the blinking red light.
  • 560 Answers
Unlpug the unit from the power outlet for about 1 minute, plug it back in and turn it on. If it doesn't work, unplug the unit again, re-seat the hard drive and make sure the connection is good.
Blinking red light indicates update process or hard drive failure.
Posted on May 29, 2010
Hello my name is Jaime now got a samsung Impression. My plantronics Explorer 220 bluetooth does not connect. Is it not compatible? thanks
Hi Jaime. You can follow theser instructions to pair a headset with your impression. Make sure the headset is fully charged and powered off before you start.
1. Make sure that bluetooth is turned on
2. Tap Menu.
3. Tap Settings.
4 .Tap Connectivity.
5. Tap Bluetooth.
6. Press and hold the on button on the headset until the light blinks red and blue. This indicates that it is in pairing mode.
7. Tap the Search button.
8. Select the headset from the list.
9. Enter 0000 for the pass key.
10. Verify Connection Options is set to Automatic.
11. Tap OK.
12. The Headset will display as a blue, connected icon.
Hope this helps!
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Nintendo DS Lite keyboard problem
Recalibrating the Touch Screen
Remove all games from the Nintendo DS Lite.
Turn the system on by pressing the POWER switch.
Press the A Button when the "Touch the Touch Screen to continue" message appears.
When the main menu appears, use the Control Pad to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. (Note : You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.)
When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Jan 18, 2010 | Nintendo DS Lite Console
My Ps3 is only staying on for 4 seconds (green for 2 seconds and yellow for 2 seconds) and then flashes red. when i tap the power button it stays red and repeats.
call sony the problem can be several things
call sony even if your console is out of warenty
i had the same problem a couple of months back and warenty was expired by a few months i called them and they gae me a refurbished ps3 free
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
Only 2 of the 4 buzz controllers work on the ps3
1. Hold the power switch on the 4 controllers till the blue light at the bottom of the controller stays on.
2. Once all the blue lights are on the controllers, hold in the button on the USB stick till it blinks.
3. Tap the button on the side of the USB stick and all 4 controllers will sync with the system.
Nov 08, 2009 | RTO Buzz Quiz Tv for PlayStation 3
Tv plays for a few minutes then goes off. red light blinking on front. have rear cover off, when tv goes off, tap tin box, comes back on. tap again goes off. don't know if easy to replace.
there are two alunium things in the middle of the board with something screwes to them. one was loose, could move it back and forth and tv would go on and off. i put a rubberband around it and a thing that looks like a small tramsformer. now it stays in the possion that the tv stays on. worked fine for 6 hours yesterday. only us the tv occasionaly so hoping it will last.
Oct 27, 2009 | Toshiba Televison & Video
It wont stay on. when i press the power button the led light blinks red. the camera is off but the lens is sticking out
It looks pretty much as battery problem, try using a new and charged one. Low charged (bad)battery can do strange things to eletronics
Oct 12, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Nintendo Wii let's tap multiplayer mode
you need to sync the controller that is going to be used
open the battery casing. press the little red
button inside until the 4 lights on the front flash
then go over to the console and open the SD card cover on the front and press that little red button
then the controller is synced and your light will correspond to Wat player you are
then go multi player
hope this helps
Jul 21, 2009 | Sega Video Game Consoles & Games
My xbox box has 3 red lights flashing... i know there are different types of error how do i know which on i have?
after turning it on, and seeing it display 3 red lights, hold the sync up button and tap eject.
The lights will change to a different pattern. This represents a number.
The number is four digits, so you'll have to hold sync and tap eject FOUR TIMES, remembering each pattern.
Pattern numbers are as follows:
4 red lights = 0
3 red lights = 3
2 red lights = 2
1 red lights = 1
Most common ones are 0020 and 0120.
Jul 17, 2009 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
