Question about Microsoft Computers & Internet
How do i change my cv to a 97-2003 program from a 2003 one
  • 38 Answers
Just open your CV and do File Save-As You will see an option 97-2003 Select that and Save
Posted on May 30, 2010
If cv joint is bad car has a lot of vibration, boots arent torn or leaking, but makes a humming noise. is this cv joint or something else?
cv joints should not click as that is the first indication of a failed unit
( going slow and changing direction produces a click,click is a cv joint)
wheel bearings should not be tight as that will produce a humming noise and will result in early failure
because the axle turns with the change of direction ,the distance from the pivot point to the transmission changes and so the shaft will move in and out of the transmission to compensate
take it to an accredited drive line specialist for a diagnosis
Jun 07, 2015 | 2000 Ford Taurus
How to replace a cv joint
I can tell you how to replace the CV joint but it is by far better to just buy a re-manufactured axle. The price of the CV joint itself then the labor to remove the axle, change the joint and install it is a big pain. Changing just the CV joint is labor intensive and you could run in to problems. Don't risk it, but a rebuilt.
Mar 23, 2014 | 1994 Toyota Camry
Can any one help me for cv 33 please
There are many versions of Casiovision software. The CV version depends upon your country. If you use the wrong version, you could damage the program. You have to match the IPL firmware in your machine to the software. For this reason, it is controlled by dealers. All you need to do is contact a local dealer and ask them for it. Most dealers will give it to you at no cost. They may charge you for training and this is reasonable because the machines that connect to CV33 are complicated POS terminals.
Most machines can be programmed and used without CV software so it is not essential to programming or operating your machine. You can program them via the keyboard on the terminal as long as you have the manual. If you need the programming manual, most Casio manuals are at C-tech:
http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
Jan 26, 2014 | Casio Parts Cash Register PC Desktop
Hi, I have a casio TE-3000s, cv-22 program and a
Go to Casio Support Webpage:
http://www.casio.com/support/authorizedservice/
Aug 19, 2013 | Casio cv-22 programming / reporting...
What's involved in changing a cv joint in a 2000 Rav 4? I have very good mechanical abilities & have changed cv joints before (about 10 years ago)
Easy enough job really, jack car up, put axel stand under. remove wheel - remove hub nut, remove pinch bolt - prise open the pinch bolt part (sorry cant rem name) pop out the hub from the lower arm. Remove CV join from drive shaft. Usually a tap will pop it out.. sometimes theres a circlip that need removing (models vary). Grease up new CV joint - put grease in new boot, pop boot over drive shaft. put cv join on (replace circlip if provided in kit). join cv to hub - attach CV boot fully. fasten hub nut, replace wheel.
done. might need tracking again or aligning once you do this.
Feb 14, 2010 | 2000 Toyota RAV4
How do i remove cv axle for a 98 isuzu trooper
Go to my profile I have just explained how to change a cv boot on a Trooper. The axle needs to be taken out to change the boot so the same solution. What you call an axle I have refered to as a drive (short for driveshaft) It takes a lot of explaining so save me a lot of writing if you read the solution I gave for changing the CV boot. Cheer's
Sep 27, 2009 | 1998 Isuzu Trooper
C B JOINTS
Hi there. Do you mean cv joints? And if so you are better off th change the cv shaft than try to take it apart and rebuild the joints. The cv joints are really difficult to put together and far more work than just replacing the shafts. In either case you need to removve the shaft with the bad joint. Pull off your wheel, brake caliper, rotor, and then seperate the lower control arm where the balljoint connects to the hub. You will need to get a balljoint press for this. You can usualy get one through a chain autoparts store rent a tool program for free(with refundable deposit). once the balljoint is seperated you need to get a prybar in where the cv shaft goes into the transmission. Just hook the base of the shaft and lightly pry it out away from the tranny. Becareful not to damage the seal at the tranny with your bar. Hope this helps.
Mar 15, 2009 | 2004 Kia Optima
Changing a CV joint
CV boot and CV joints are different. Boot covers the joint which protects it from debris and other harmful things. if your boots are cracked then just change them. pretty cheep to do yourself. but if you look at the joints and there is dirt on them then you have a problem. i have that same thing and its fine for me unless i turn on the 4W. then you hear a clicking noise. eventually if you keep going like that your car will stop moving. you can look to buy new cv halfshafts. for a good price go to pep boys. best deal i've found anywhere
Oct 15, 2008 | 1999 Honda Passport
When turning hear a clicking noise from drivers front wheel 1999 mazda millena s
most likely the cv boot is bad will need to be replaced recomend change the whole cv axle
Jul 29, 2008 | 2000 Mazda Millenia
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
