Question about Denon DN-S3500
Platter quit spinning
I was just playing a track then the platter stopped spinning. If i manually spin the platter, it will read the track and will have audio as a regular turntable would if the power was turned off... It will work on "pitch bend" mode though, ( will have audio and everything ) but as soon as i change back to scratch mode, everything stops, where before the platter would start spinning again with no interruption of the track playing. Is there something I could try to fix it?
    Problem Solver:
  • 17 Answers
Sounds like the motor drive controller might be malfunctioning. An authorized Denon service center would have to take a look at it to make sure.
Posted on Mar 10, 2009
Carosel on my cdp-c545 spins freely but not mechanically
Take the screw out of the middle to take the platter off and make sure the drive belt underneath is still on.
Jun 18, 2013 | Audio Players & Recorders
Wurlitzer 1015 cd player that wont read the cds bot the drive motor spin real fast ???
That usually means the Laser can not pick up the CD surface. I have not worked on Wurlitzer CD but have worked on hundreds of other units and the technology is the same. It could be the platter distance is too far from the pickup or that one of the six laser pickup has burned out to allow correct tracking. There is a Focus OK signal that has to be satisfied first, then spin up and data reading of the TOC. f it can not do that they may spin wildly.
Dec 24, 2012 | Wurlitzer Jukebox 1015 One More Time...
Cd platter on PD-S701 wont spin
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD. If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Mar 12, 2012 | Audio Players & Recorders
I'm having two problems with this unit , a SONY CDP-CE375 5-CD Changer, which I bought several years ago. The first problem: Occasionally, the CD doesn't seem to be seated properly when I close the platter...
Granted, they don't actually SAY you should carefully place the discs into the detents designed for them on page 7, but that is the expectation.
http://www.retrevo.com/support/Sony-CDP-CE375-CD-Players-manual/id/423ci261/t/2/
As for audio hum,
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Consider the presence of light dimmers, too. Mine induce buzz when the lights are on.
Oct 17, 2010 | Sony CDP-CE375 5-Disc CD Changer
Technics Sl-DZ1200s skipping on one deck
Change the motor disc spindle they are all the problem
Jul 03, 2009 | Technics SL-DZ1200 CD Player
The platter got stuck in the open position.
Drive belt for door and for platter need replacing
Jan 06, 2009 | Harman Kardon FL8385 5-Disc CD Changer
Getting errors reading the first (data) track on mixed-mode CD, what can i do? get error message "TABLE ERROR"
The CD Player platter does not spin or displays Table Error.
Follow this procedure when the platter of a CD Changer does not spin or displays Table Error.
  1. Open the door to the unit.
  2. Press the center button in the Jog Dial, and attempt to remove all the CD's in the unit. NOTES:
    • Verify that all the discs that were installed in the unit are removed. If all the discs do not come out, the unit will need service.
    • If the player is not operating correctly, reinstalling CDs may damage the CDs.
  3. Attempt to rotate the platter with all discs removed. If the platter rotates, install a few discs to verify operation.
  4. If the platter does not spin when the unit is empty, service will be required.
Also are you getting any other specific error codes, if so, please let me know what they are.
Please get back to me and let me know any other specifics.
Please don't forget to rate this. Thank you!
Mar 27, 2008 | Sony MegaStorage CDP-CX333ES 300-Disc CD...
Faulty drive motor
You can replace the spindle motor to resolve the problem. It is quite a common fault. A quick fix that sometimes holds, is to remove 1 only of the 2 mounting screws from the top by coming in at an angle with a jeweler's screwdriver(if you are lucky the platter may have an access hole), and put a quick squirt of CRC 2-26 into the motor using the straw that fits to the cans nosel(if you don't have the straw, a syringe will do), enough to "flood" it, but not enough to get it everywhere. Then fire the unit up and put it in play mode-repeat track 1, this spins the cd at the highest speed and cleans the commutator and brushes enough to get the motor back to serviceability again. Removing the motor completely and running it on the bench using 6-12 volts for 10 mins and then reverse direction is even more effective. If you pull the spindle platter off the motor, be sure to measure with a steel ruler the deck height it sits at so as to reinstall it to the exact same height will also Good luck with your repair. A FixYa rating for this techo know how would be great thanks :)
regards
Graeme
Feb 15, 2008 | Audio Players & Recorders
Abnormal Acceleration of Platter
Sounds like it may need a motor calibration. You would have to seek out an authorized service center to this adjustment done. It's a quick and easy fix though.
Jan 14, 2008 | Denon DN-S3500
Platter stops when back scratching
i had same problem, just took mine back and exchanged for new one. however i'm having a similar problem again. i tried polish to make it more slippy, and tried cleaning under grey platter, but now i've made it worse, and i get a clicking sound when my cd's are playing. any technics dealer should be able to get it serviced for you.
Oct 17, 2007 | Technics SL-DZ1200 CD Player
Denon DN-S3500 Logo
384 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
