Question about Toro Electric Ultra Blower/Vac 12 Amp
My 12 amp Toro leaf blower is 12 years old and worked fine until I tried to use it a week ago. When I started it I could see blue sparks inside the motor housing and then the motor quickly began to smoke; the smoke smelled like burning metal. A friend and I took it apart and my friend says the blower is sparking and then smoking because the brushes have worn down and are making poor contact. I tried blower again yesterday and sparks & smoking started almost immediately. Do you think the problem is just the brushes or something else? Given your diagnosis, do you think the blower can be repaired at a reasonable cost or is it best to give up on it and get a new one? ANY advice will be greatly appreciated! John M.
  • biker311 May 30, 2010
    I am primarily interested in knowing whether the symptoms I described about my leaf blower could be caused by something other than the brushes, and given your answer whether you think I would be better edvised to purchase a new blower rahter than attempt to fix this 12 year old model - I have never had a moments trouble with this blower until it starting sparking when I first started it after it sat all winter.
    Thanks
  • 344 Answers
If the brushes have worn down to the extent you are describing I would think that the motor wouldn't be in great condition either and given that the price of these blowers is only $75 I would be tempted to buy a new one.
http://www.deerso.net/Toro-Outdoor-51592-Super-Blower-Vac/M/B000O27BM4.htm
Posted on May 30, 2010
  • Tony Groves
    Tony Groves May 30, 2010
    I don't think Toro actually sell spares for this blower as it is considered a throwaway unit.
  • 1,284 Answers
Hi, i think your friend must be a tech to have discovered the real cause of the spark which lead to the smoke. Actually the worn out brushes can be replaced but i don't know the price to get it for and i believe it will be reasonable than getting a new one which will definitely cost you more. Just take it to a tech to fix properly..
Take care
Posted on May 29, 2010
  • Shehu Pro
    Shehu Pro May 30, 2010
    Hi, as i have said earlier, the spark was caused by the worn out brush and if you said the blower is 12 years old, i would advise you to get a new one instead of replacing it...
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Motor won't turn on
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Blower does not turn on
Apr 03, 2014 | Toro Garden
Snow blower shorted out
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Toro Electric Ultra Blower/Vac 12 Amp Logo
160 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
