Question about Casio EXILIM Card EX-S770 Digital Camera
Locked Hi, Camera has been fine till I took the memory card out to process the images. When putting the card back and turning it on the camera says "The card is locked" I can see my images but cannot use the camera. Please help. Sian
  • 123 Answers
Look on the side of the card. There is a little switch. When you took it out of your camera you must have bumped it into the Locked postion. Just move it in the other direction and you should be set.
Good Luck.
Posted on Apr 08, 2008
6ya staff
SOURCE:
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
Playsport zx5 won't shut off. Was recording and it just locked up. The screen still shows what the lens sees, but the recording locked up after 4:18. Camera has been on for 3 hours now...
I had this problem. It turned out to the sd card was causing a problem. I took the card out and hit the reset. The turned it back on and it it working great. I ended up copying all the images off the card onto my computer then put the card in the camera and reformatted it. The copied all my images back on to the computer and it is working fine. Hope this helps.
Jun 08, 2011 | Kodak PlaySport Zx5 (0.128 GB) Flash Media...
PowerShot SX10 IS Digital Camera: I took my card out, when I put it back in it says ...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
May 18, 2010 | Canon PowerShot SX10 IS Digital Camera
No image shown
If you took the pictures, and stored them on the camera's internal memory, then put in a memory card, it will read from the card and you wont be able to see the photos that are actually stuck on the camera. Try removing the SD card, then check for your photos.
Conversely, if you took the photos when the card was in, and then removed the card, the photos wont be stored on the camera, so you should look for the card.
Jun 23, 2009 | Polaroid i634 Digital Camera
Took memory card out to print at Sams Club- said "No image"? placed memory card back in camera and when turned on camera diplay said "No Image"? did not delete them- are they in camera and I can recov
Most cameras have built in memory. Remove memory card and turn camera on in play mode. If you see the pics then they in cam memory ; take camera to photoshop they will download it for you.
Please tell me you found them I have a 2nd grader and I know how imporant these memories are for us especially.
May 12, 2009 | Canon PowerShot A470 Digital Camera
CARD LOCKED
There should be a small toggle along the end side (it is tiny and easily missed, but it is there, I just checked my memory card / mine is 4GB SD card from Sony) that you can swtich to unlock and your images may come back that way.
Look for it this way, hold the card face down it should be on the back edge where you use your thumb or finger to push it into the slot on your camera.
Mar 03, 2009 | Canon PowerShot A540 Digital Camera
Exilim camera, PNY optima SDHC memory card error
Hi
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Nov 10, 2008 | Casio Exilim EX-S2 Digital Camera
Card Locked
you have to use the origanal samsung chip try samsung.com
Feb 23, 2008 | Samsung Digimax S730 Digital Camera
Memory card locked!??
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Memory card problem
Download PC Inspector from www.convar,com run the stick through this program- if the images are there it will find them But of course no images may have been recorded Sony Tech Help Team will tell you more about the meaning of 'Access'
Jun 23, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
98 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
