Question about Hanns.G Corporation HW-192D LCD Monitor
I have just got a new computer with a hanns.g monitor, but when i turn the monitor on it is saying no signal input check video cable, what does it mean?
  • 11,361 Answers
It means it does not receive the video signal from the PC video card, check all pins on the video cable, also try this monitor with other PC.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 30, 2010
No signal check video input
Did you check the video cable? Try it with another PC? The PC may not be sending out the video signal to the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 13, 2011 | Hannspree HANNS G "HW173DB" 17in...
No video signal, says my HannsG HW191D LCD monitor
This message occurs when the signal from the computer is absent, as in the computer is shut down or the cable is unplugged etc.
Apr 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
The monitor starts up displaying no signal
This means that the monitor is not receiving a video signal from the computer. When it doesn't receive a signal, it goes to sleep. You should check to make sure that the video cable is tightly connected, and also, if you have another monitor around, connect the other monitor to the computer and see if it works. It's possible that your monitor has malfunctioned.
Mar 03, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Is it possible to use HW173D monitor with DVR and security camera
Unless your DVR offers a VGA output connector, you won't be able to use your monitor simply by plugging in a cable. The monitor VGA input requires separate signals for each color (red, green and blue) and synchronizing signals (vertical and horizontal). If the DVR has only composite video out, you'll need a video to VGA adapter. These are available from many online sources. They aren't cheap since they are active electronic devices, but many are in the $50 to $75 range. Here is one typical result from a Google search for "video to vga converter". You might also check eBay or local sources such as craigslist to see if anybody has bargains.
Feb 10, 2010 | Hanns.G Corporation HW173D Monitor
WhenI turn my monitor on, a screen appears saying VGA input - no signal & DVI input - no siganl & then it goes to sleep
Do you have multiple Video cards installed in your computer?
Check the monitor on another computer to verify the Monitor works and so does the cable.
If Monitor works, cable works, and you have 1 video output from your computer, then your Video card is probably no good.
Jan 26, 2010 | Compaq fs740 17" CRT Monitor
Monitor says: no signal input check video cable Even though the computer is on.
Sounds a bit bland but either the monitor has failed or the video card
Only test is to plug your monitor into another system and see if it comes to life
If it does then your video card has expired.
If it is part of the motherboard then the easiest option is to buy a replacement which plugs into the AGP slot
They are dirt cheap unless you are into gaming when the sky's the limit
Jun 27, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Monitor says: no signal input check video cable Even though the computer is on and hooked up
if it says so....it indicates that the display card is gone bad. check with the display card...
or try inserting New Graphic card or PCI VGA card... works for sure....
Jun 23, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Hanspree monitor says,''No signal input check video cable''
ask the shop for a replacement cable. it could be broken.
Mar 26, 2009 | Computers & Internet
Screen
Just turn the monitor off and on,,it should cure the problem,,also,,,tap the space bar on your laptop,,,,also,,you may want to change your settings on your laptop to prevent it going into sleep mode, or standby state,,which is what is causing this problem with your monitor.
Jan 19, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Hanns.G Corporation HW-192D LCD Monitor Logo
786 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
