M375c clevo bios problem .message at post cmos cheksum invalid run SCU.. if i it f2 go in bios but can not do anithing. ! have a new cmos battery. and no disk to reinstall.
    President:
  • 567 Answers
Hi there welcome to Fixya, you need to set the CMOS settings in the BIOS and if you are not seeing anything on you computer screen you need to double check the connections inside the computer because the hard drive may not be connected properly or the monitor cable may be move or the memory may be move without showing any physical sign during installation of the new CMOS battery. So please check all of these components carefully then restart the computer. Thank you
Posted on Jun 03, 2010
  • 3 more comments
  • feu26 Jun 04, 2010
    i see the screen , but when i punch F2 it goes in bios page, but i cannot access the bios itself . neither the mouse or keyboard is working when i enter the first bios page so i can't go further
  • feu26 Jun 08, 2010
    any better solution ?
  • Hilton Bristol Jun 08, 2010
    You can try reseting the BIOS, to reset the BIOS you need to shut down the computer open it and remove the CMOS battery then put it back in after about five to ten seconds.The CMOS battery is a small round battery located on the motherboard after you reset the BIOS you can start the computer and see if that will solve the problem if the problem still exist you should replace the CMOS battery.
    If this solution solve the problem you can give it rating and vote.
    i have try that since i change the cmos battery as state in my question and it did not worked
  • Hilton Bristol Jun 09, 2010
    You can start the computer hit F8 to get the options select start in safe mode with networking connect to the internet and go the manufacturer website and download BIOS update for your computer here are a few websites you can get free download of drivers and updates for your computer: http://drivers.top4download.com/free-cle...
    http://drivers.softpedia.com/progDownloa...
    http://www.findmysoft.com/drivers/Clevo-...
    if you get online in safe mode with networking that would give you a chance to fix the problem , if the problem still exist after you try these solutions, you can checkout this website http://restore-disk.com/restoredisks/Cle...
    they sell the BIOS recovery software for your computer.
Locked out from eee box 1035 need to reset bios how?
Try this. Right out of the manual. The reset button is the little pin hole next to the power. Will need a paper clip that is straightened.
Entering the BIOS Setup
BIOS (Basic Input and Output System) stores system hardware
settings that are needed for system startup in the PC.
In normal circumstances, the default BIOS settings apply to most
conditions to ensure optimal performance. Do not change the
default BIOS settings except in the following circumstances:
An error message appears on the screen during the system
bootup and requests you to run the BIOS Setup.
You have installed a new system component that requires further
BIOS settings or update.
WARNING!
Inappropriate BIOS settings may result to instability
or boot failure. We strongly recommend that you change the BIOS
settings only with the help of a trained service personnel.
Quickly enter the BIOS
Windows8 boot time is quite fast, so we developed the following
three ways for you to quickly access the BIOS:
Before booting up the system, insert a straightened paper clip
into the BIOS Reset key.
BIOS Reset key
Press the power button for at least four seconds to shut down
your PC, then press the power button again to turn your PC back
on, and press F2 during POSt.
When your PC is off, disconnect the power cord from your PC's
power connector. Reconnect the power cord and press the
power button to turn on your PC. Press F2 during POST.
Oct 16, 2013 | Compaq Presario 5000 PC Desktop
I have a challenge for you experts.A friend ask me to see if I could repair his computer he was given by his mum that was in the atic for at least 6 month (Packard bell i design 190) I put all the cables...
WOW, this sounds so familiar, try changing the CMOS battery, I got the same exact error mess in a old packard bell i refurbished for a friend and a simple change of the cmos batter solved the issue, it even let me install xp with not problem,, its worth a try.... :)
Sep 04, 2011 | Computers & Internet
Forgot my password
In computing, BIOS (basic input output settings) refers to the information stored regarding a computer's hardware configuration, the system date and time and any applied password. This information is known as the BIOS or CMOS settings--the BIOS is stored on a small battery-powered semiconductor chip known as the CMOS (complementary metal oxide semiconductor). Having a CMOS or BIOS password restricts unauthorized changes to the system's hardware configuration and, in some computers, may even be required for booting. A lost password may be reset by removing the CMOS battery, clearing the motherboard jumper or using a software-based password cracker.
1.Shut down the laptop and unplug its power cord from the wall outlet. Remove the battery cover under the laptop and gently raise the battery from its dock. Unplug any peripheral devices with a live power source connected to the laptop, such as a modem or printer.
2.Locate and remove the CMOS battery. Refer to your user manual or visit the manufacturer's website for your laptop's architecture. Follow manufacturer recommended procedure to access and remove the CMOS battery. Depending on make and model, this procedure may be more involved for some laptops and not others. The CMOS battery is a flat circular shape and resembles a watch battery.
3.Wait 30 minutes and then put the battery back in. This will erase all information stored in BIOS. Assemble the laptop, making sure you leave no loose connections. Power up the laptop and press "F1" when you get the "CMOS cheksum error" message. Type in a new password.
Clearing CMOS Jumper
1.Turn off the laptop and access the motherboard following recommended procedures.
2.Locate the jumper in the motherboard. If you do not have your motherboard documentation, locate a single jumper near the CMOS battery. In some laptops, the jumper may also be labeled in the motherboard. Put the jumper setting to "Clear" and reassemble the laptop.
3.Turn on the computer and hit "F1" when the "CMOS checksum error" message is displayed. Navigate through the BIOS settings interface to load default settings and apply a new password.
Using Password Remover
1.Download a software-based BIOS password cracker. There are numerous free programs able to recover or delete CMOS or BIOS passwords from virtually all motherboard brands. Download the file from a trusted source and save it to the desktop.
2.Burn the installed file to a CD using image burner software. Insert the CD and access the password remover tool.
3.Note the password or use the program to set a new password.
I hope you find it very helpful. Thank you.
Aug 22, 2011 | Acer Aspire One PC Notebook
BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
Jun 06, 2010 | ASUS Eee PC 1000HE Netbook
Checksum Error after Bios Upgrade K7VZA
Have you tried resetting the CMOS? Often, after upgrading BIOS you need to clear the CMOS and re-setup to handle the new features. You should have a jumper to clear CMOS, or you can remove the power from the system and remove the battery for a few seconds to clear it.
Let me know if this clears up your issue.
Sep 19, 2009 | EliteGroup K7VZA Motherboard
Cmos cheksum bad
From your problem description, it sounds like a corrupt BIOS and or a failing motherboard.
Due to the system age, I'd say cut your losses, salvage what drives are usable, and get a new (or newer) system
Dec 07, 2008 | Computers & Internet
Bios failure
you may have a flat cmos battery, but first try reseting the bios by the cmos reset terminals, refer to the manual
Sep 14, 2007 | ASUS A8V-VM Motherboard
Computers & Internet Logo
432 people viewed this question
David Payne
David Payne
