Question about Sharp Audio Players & Recorders
I bought a Sharp's Micro Component System some 5 years ago (27/11/05), it has remained in the box as new and I have just recently started using it. Within the last 3 months it has been played about 4 times in total since new and I now find that it is not working correctly. It is a multi disc player Model XL-MP150E, what I find is that the disc's do not play in sequence and sometimes they do not play at all without regecting part way through. In my home I have 4 TV's 3 of which are Sharp's and 3 Music Centres of which there is only 1 which is Sharp. Therefore as a loyal Sharp customer I would be interested, to know what you suggest because theretically the Unit is still new.
  • Sharp Master
  • 5,568 Answers
I have bought things intended for future use but have never left anything in the box untested. With the speed of assembly and manufacture, junk gets shipped by every company so one needs to know early if an item is DOA or not.
I don't think you have any recourse but to have it repaired at your cost or add it to the huge pike of other dead Asian electronics.
Posted on May 29, 2010
I had a power cut a few weeks ago, I can not find my user manual for my sharp ba 1200 system, I know that I need to press three cetain buttons to re set the micro computer in order to set the clock to get...
What's a Sharp BA 1200? Web search for "(exact product) manual".
You might find it at the manufacturer's support site, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
Aug 15, 2011 | Sharp Multi-System Mini Component System...
My Dell Studio 1737 integrated webcam does not work
I recently purchased a new dell laptop and had similar issues out of the box. I ended up having to format the drive and re-installing the operating system from the disk provided because the original install was corrupt.
Sep 02, 2009 | Dell Studio 1737 Laptop
Microwave problem or electricity circuit problem?
It sounds like there is too much running off that one power line in the house... its starving for power which will take from where it can such as UPS fridge or freezer - other than that it could be a faulty junction box or wiring so you would probably want to see an electrician about it before there is a fire... If too much power is sucked from one wire it may get very hot!
May 05, 2017 | Sharp R-320H Microwave Oven
Sharp Micro Component System XL-ES50 won't turn on
my copies sharp mx 2700n how to go SP mode and i get eroor code h5.01
Dec 22, 2008 | Sharp XL-ES50 CD Shelf System
Machine won't turn on when I push the button
I had the same problem with a Fisher & Paykel Smartdrive 701. First try disconnecting power lead for 5 mins, then plug back in and try again. It sometimes resets itself. Second try is the fuse. Take off the control panel cover (2 screws), open the blue control box (the larger one still mounted in the machine) and you'll see a simple fuse. If you're lucky this is a very cheap fix and hopefully didn't blow for a reason.
If the fuse is OK then it will be the main circuit board blown in the smaller blue box that comes off with the control panel. F&P don't sell component parts for these like a simple blown micro-switch, and a new board is $200+ labour to fit.(5 mins)
Great washing machine but my boards only last 4 years between replacements. Have now bought their new Aquasmart machine.
Good luck.
Eddie.
Sep 08, 2008 | Washing Machines
CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Apr 09, 2008 | Sharp XL-HP515 CD Shelf System
1080p ** Longer Available, problems switching to 1080i.
I'm a sharp servicing technician and since both the component and hdmi have problems, Im leaning towards the Main board also. If it was the digital board, only the hdmi would have a problem.
If you do end up replacing the main board. ONce youve installed it, check to see if it has the latest firmware version. New boards from Sharp are supposed to be preloaded with the latest firmware, but sometimes they are not.
A firmware upgrade is possible because it deals with this sort of DVI/HDMI compatibility issue. It would be the easiest and cheapest fix. Enter the Service Menu to check what version you have. The latest is version 1.31
good luck.
Mar 10, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
XLMP131 - Can't erase memory
You can download the manual from the manufacturer's web site at
http://www.sharpusa.com/~/media/39A805D2F18A45A48E0C7A2594C6F37E.ashx?aud_man_XLMP131.pdf
Dec 26, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
90 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
