Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
It wont heat
Ive completed all the trouble shooting, pretty sure I need to replace the heating element, can not find the scematics in my paperwork like in the old days....just to find my way around with the cover off...
  • 156 Answers
GIVE ME MORE INFERMATION I CAN HELP
Posted on May 30, 2010
Maytag MIR8890AS0 6.2 cu.ft. induction range w/true convection. Takes an hour or more for oven to pre heat, doesn't maintain heat. 4 yrs old. Induction top OK.
I don't know, but it sounds like one of the heating elements are burnt out/no longer working. I had a similiar problem 5 years ago.. they're pretty easy to replace yourself if you are handy and have a screw driver. I think the one for my stove cost $18 to replace (5 years ago) here's the trouble shooting guide online for you model:
Maytag Range Stove Oven MIR8890AS0Troubleshooting Repair Help
Dec 07, 2016 | Maytag Kitchen Ranges
Type 60870 not heating water!Have a wiring giagram for trouble shooting?
Could be: faulty power board (completly or only relay for heating element), faulty wiring between heating element and power board, faulty heating element (interruption, short circuit or current leakage,on some heaters faulty thermal protection).
Depending on the model, the display shows the i60 fault code or the LED end of the program will flash 6 times (only model without display).
Dado
Mar 17, 2015 | AEG 24 in. Favorit 60870M Free-standing...
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Any trouble shooting tips. My heating element under the rollers is not working
The heating element may have burned out - do you know anyone who can test it?
It may possibly also have a thermal fuse inside - that's not something you can easily replace, but it's cheaper to have someone replace that then to have them replace the heating element.
Jul 31, 2014 | Nostalgia Electrics Hdc 701 Carnival Hot...
Beko wma 1512s not heating up and ive replaced element still not working?
possibly bad gas valve or your venting is clogged with lint.go on the outside of your house and make sure the air is blowing out strong
Nov 09, 2013 | Washing Machines
Hot tub doesn't heat
Steve- go to http://www.hottubworks.com/ and check out the heater trouble shooting guide. Pretty easy to narrow it down. Most common is filters being clogged (lack of flow) or heater element has burned out (easy to replace) there is a video how to do it.
Oct 02, 2012 | Master Heaters Master Hot Tub Filter
Turns on but wont get hot
Hi
The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
http://www.dryernotheating.com/
http://hubpages.com/hub/How-To-Replace-Your-Dryer-Heating-Element
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Roper REX4634KQ Electric Dryer
Deep Fryer Element Won't Heat Up
Look for the reset button and it should come back on. I just did and lights came on immediately.
Nov 06, 2007 | Rival CZF625 Deep Fryer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
69 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
