Question about Toro 89885 "lawnboy" Premium 4cycle Oil 20oz
My lawn mower starts, runs for about 5 seconds and then dies. I need to prime it in order for it to start. It will keep running if I continually keep priming it. I have bought new gasoline, changed the oil and changed the spark plug and the same problem continues.
  • 2,926 Answers
The engine is starving for fuel, that is why it will keep running while you force the fuel to the engine with the primer button. At this point, the carb will have to be removed,disassembled and cleaned. I'm sure you will find blockage and dirt in the carb and also in the small orifices for air and fuel flow.
Posted on May 31, 2010
  • paul_bachand Oct 12, 2010
    Thank you for your help. I was able to fix the problem without pulling the carb apart. I took off the air filter and poured some fuel down it. I got very lucky
Dynamark 3.5 Model 20211X18A. Looking for manuel, I prime 2 times to start. Engines starts then dies. If I continue to push prime button it will keep running, barely, however, dies as soon as I stop...
Could be 2 things: a restriction in your fuel line/coming out of the tank, or 2: a dirty carburetor needing to be removed, cleaned and possibly rebuilt and reinstalled. Hope it's one of those.Start with pulling the fuel line loose from the carburetor. If you have fuel flowing freely, plug the hose with a golf tee and move onto removing the carburetor. Carb kits are cheap and easy to install. It's best to rebuild while you have it off to avoid similar problems later.
Sep 30, 2013 | Briggs & Stratton Briggs Stratton...
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
Sep 03, 2012 | Poulan Pro 22inch 625 Series Briggs ...
My Craftsman lawn mower has a problem. After starting, it only runs a few seconds, and then dies.
There are a few things you may want to try. One, the float in the carb may be stuck. Try putting a small amount of gas directly into the carb, this may free the float. Two, try replacing the fuel filter, it may be that some fuel is getting to the engine but not enough. Three check the air filter, same as with fuel the engine may be getting some air but not enough to continue to run. Hope this helps.
Jul 19, 2011 | Garden
I have a Sears (Craftsman) mower model # 944.368300. When I prime it, and attempt to start it, it runs for approximately 5 seconds and then dies. If I hold the primer button in, the mower keeps running. ...
Try removing the brass bolt that holds the float bowl to the carb on and cleaning it thoroughly. This bolt is the main jet for the carb and can become clogged with varnish or debris esp. if no inline filter is used or gas is allowed to evaporate in the carb. There will be small holes on the bottom and the sides where there are no threads. If no other problems, this should cure the 5 second run.
Please vote on this solution.
Sep 04, 2010 | Craftsman Air Filter 33021 2 pk for Lawn...
Lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Jul 05, 2010 | Poulan "Poulan" Push Mower
What would cause mower to die after starting?
your carb. is gunked up. get a can of starter fluid and a helper. have the helper spray some starter fluid into the air intake to keep it running after it starts. Once it runs for a couple of minutes it will be ok. J.
Jun 27, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
Wont continue to run after prime and start
often the last ounce of gas in the tank has some crud in it. Get a can of carbeurator cleaner spray. Remove the air filter and squirt three short bursts of the cleaner spray into the air port and then start it. Keep giving it short bursts of carb. cleaner until it runs smoothly again.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
May 17, 2009 | Craftsman Garden
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Toro 89885 "lawnboy" Premium 4cycle Oil 20oz Logo
951 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
