Question about Olympus D-545 Zoom Digital Camera
Card error I've just gotten back from a trip. When I turned my camera on, a Card Setup screen appears and my two choices are Power Off or Format. When I pull out the memory card and put into the memory card reader in my computer, it says that the disk must be formatted before it can be used. Have I really lost all 200+ pics from my trip or is there anything I can do to save them? Any help would be greatly appreciated!
  • princeza Apr 08, 2008
    I can't get to the photos on the card, that's the problem.
  • princeza Apr 09, 2008
    Yeah, it says that the card needs to be formatted before it can be used.
    President:
  • 1,944 Answers
Use a card reader connected to a PC to backup your photos and then reformat the memory card.
Posted on Apr 08, 2008
  • Damen Wong
    Damen Wong Apr 08, 2008
    Even with a card reader it gives an error?
Canon sx20 lens error
From your description it appears to be a mechanical problem. I doubt you can get it repaired in time for your trip.
I suggest you put your money towards a new camera and you maybe able to use the SD memory card from the old camera after you format the SD memory card in the new camera.
Apr 16, 2012 | Canon PowerShot SX20 IS Digital Camera
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Trying to download photos from computer card reader. An error occured. Put card back in camera, switch on power and camera goes to card setup screen, alaem sounds and the choices are power off or format....
It sounds like you already know better than to reformat the card whether on the camera on on the computer, for you will for sure loose all the pictures. A couple of steps you can try;
- try another card
- try using the cable that came with the camera to connect the camera to the computer, this will at least enable you to get those pictures saved before loosing them
- try a different card reader, while they do seem fairly simple I've encountered some work for some cards better than others. it can be a cheap one, just another one.
- make sure your battery is fully charged and that the camera was stored in a dry place (humidity has been known to start wreaking havoc in the internal workings of a digital camera, even the humidity from a warm closet/garage)
- if all else fails, contact Teleplan Camera Repair they will be able to assist and repair.
Aug 04, 2010 | Olympus FE-120 Digital Camera
Why My kodak dc280 can not read the memory card?
Try formatting your camera memory card If you own camera memory cards that have been used in other digital cameras, the card may not be properly formatted for use in your camera, or that data on the card may become corrupted. When these issues arise, your camera indicates that the camera memory card needs to be formatted.
When you format a camera memory card, all of the information on the card is erased. This includes any borders supplied on the card.
  1. Set the Mode dial to Camera Setup.
  2. Slide the POWER switch to the right to turn on the camera. The main Camera Setup screen appears.
  3. Press a updown_icon.gif button until the format_icon.gif icon is highlighted. format.gif
  4. Press the DO-IT button. The Format Memory Card screen appears.
  5. Press a updown_icon.gif button until CONTINUE FORMAT is highlighted.
  6. Press the DO-IT button to format the camera memory card and return to the main Camera Setup screen.
Dec 10, 2009 | Kodak DC280 Zoom Digital Camera
When I turn on the camera,it says 'card setup' with choice power off and fotmat
This is a problem with the card you are using. If you use a different card the camera should work properly. Unfortunately I have not figured out a way yet to save the pictures on the card that is erroring.
Jul 16, 2008 | Olympus Camedia C-350 Digital Camera
Olympus FE-210 Camera Problem
Format the card, this error idicates that some required data is missing from the card .
Feb 26, 2008 | Olympus Camedia C-350 Digital Camera
Olympus C-750 Trouble formatting card
have u tried to format the card on the computer??? try to format in a card reader.... and after on the camera. if that doesn´t work... could be the kind of card, there are diferent kinds of xD cards. good luck
Apr 02, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Faulty memory card - card error.
hi, May be, it is possible, but take a chance, try with another memory card, i hope you will get it from your friends. check the camera with that, if camera works properly means problem in your memory card.If camera not works means,there is something wrong in card accessing circuit of camera. If so go to olympus shop. also try to format your memory card with pc and then check the camera with that. good luck
Aug 01, 2006 | Olympus Camedia C-300 Zoom Digital Camera
Open Questions:
Olympus D-545 Zoom Digital Camera Logo
57 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
