Question about Hunter 30124 Air Conditioner
Ac is not able to start model no 47200 - Hunter 30124 Air Conditioner
Need AC power cord for task force model 202754 tire inflator
This a battery jump pack that is used to jump start a car. Some units have an ac adapter built in so you can charge the battery in the jump start pack. My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack. My ac adapter has been lost. I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz
I understand that the DC output needs to dc12v. I do not understand the milliamps. The battery in the jump box is 12v 10 ah ( what ever that is). I just want a new ac adapter to charge the jump pack with that is not going to damage anything.
Oct 19, 2017 | AC Cars & Trucks
Whirlpool matermind window AC shows error code F2 when power on and won't cool. Sometimes it starts up perfectly fine.
F2 ---for me its a sensor problem had it done thanks katsaras
Unit -- Whirpool AC Model no. Wasr18k20 1.5 ton split AC
Jul 25, 2012 | Heating & Cooling
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
My ac gives a smell as soon as its switched own,there is no water dripping from the outlet and even it show FL sign on display insipe of cleaning the filter.what to do?
Well a smell like that indicates a short either to the fan motor, loose wire or start capacitor in most cases. I have been searching for a model number so click here and tell me which one is yours and I will help you locate your AC's problem=> All Whirlpools AC's Model Numbers and Parts I think you have a loose connection,bad start capacitor or possibly fried Circuit Board. Please Be careful in this area unplug first. See if you can locate that model number and we will go from there, Thanks, Sea Breeze sea_breeze_156.jpg
May 01, 2011 | Whirlpool Heating & Cooling
AC Adaptor lost
Will any power adaptor 12 volt DC charge a Vec013
Thanks
Apr 07, 2010 | JUMP START SYSTEM
RPM Is Very High On AC Load
check the solenoid that control the engine RPM the solenoid will work if the compressor run, this will increase your rpm when AC on. location near the carburetor.
Jun 11, 2009 | Oldsmobile 88 Cars & Trucks
2005 Chevy Avalanche Transmission Problem
i had the same problem, its the torque converter. I took my 05 c/a in because i was having shifting problem, the long and short of it is there is a breather on the tranmission that sucks in water from the road. the water and the atf dont mix. the dealer put in a torque converter and changed the fluid and installed a redesigned transmission breather.
Feb 15, 2009 | 2005 Chevrolet Avalanche
BROKEN ANTENNA BROKEN AC/DC ADAPTER
I just started to put some stuff on ebay and I have new one ac/dc adapter Model # ae9512
Good Luck!
silverrockny (my ID on ebay)
Store nameon ebay: The right Stuff Store
Oct 27, 2007 | Emerson iP100 Clock Radio
Hunter 30124 Air Conditioner Logo
89 people viewed this question
Top Hunter Heating & Cooling Experts
1STHVACMAN
Jay Finke
Jay Finke
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
