Question about Kenmore 72055 Air Conditioner
It blows out black stuff. - Kenmore 72055 Air Conditioner
Blows out black spongy looking stuff from inside. I clean the filter weekly.
filter is degrading and is coming out from inside the unit , replace filter with new one
Apr 12, 2016 | Filter Heating & Cooling
I cleaned filter still black stuff blows out it feel like foam filter is not foamthatiwash
Order a filter replacement...
Your filter sounds as though it's so old that it's disintigrating and bits of it are being pulled into the evaporator coil which in turn reduces the efficiency of the coil...
Nov 05, 2015 | Everstar Portable Air Conditioner MPK-10CR
My unit blows out black soot looking stuff, and it smears when touched, and my filter is clean. What is it? And how can I get it to stop?
Carol, the first thing I would suspect would be mold in the insulation within the blower compartment. Sometimes the cooling coil overflows, causing the fibreglas insulation to get wet which in turn allows mildew/mold to form in that compartment.
Severe cases will sometimes discharge nasty stuff as you describe coming out of the ducts.
Turn off the power and remove the blower compartment cover and investigate.
Oct 01, 2015 | Frigidaire Heating & Cooling
Blowing black smoke
far too much fuel not getting completely burned upon iginition.
That leads on to look at:
-fouled fuel injectors, (clean them - run injector cleaner)
-lack of air to the intake (filter and clear out tubing),
-spark plugs are fouled, (replace them, ensure wires seated correctly on plug)
-ignition power is low or partial, (ignition system module not sending enough electricity to plugs)
-ignition wires are bad, (check/replace)
-ECM is failing or getting bad sensor readings. (shop diagnosis)
-cat convertors have been removed and sensors are at fault
Its a long list -- do the easy stuff yourself, leave hard stuff to a shop diagnosis.
Mar 28, 2015 | Cars & Trucks
What is the black stuff blowing out of vents?
Mold. Moldy dust. You need to clean your unit.
May 09, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
No sound at all; not even from the headphones. The cooling fan is not functioning. Tested the three fuses, they appear okay, have resistance.Power supply puts out. I suspect amplifier, but is the black...
If no sound present - I'd go along with you about the amp. If you can turn up the volume and hear hiss getting louder, than the amp is probably good and the input level portion of the circuit or earlier is the culprit. Since most of the "heavy lifting" in audio devices is done by the amp - it's a logical point of failure.
If by "black stuff" you mean the surface of the circuit board and components are covered in a black residue - yes, a failure has occurred. There should be a very distinct odor of burnt electronics present. Electrolytic capacitors bulge and can even "blow up" when they fail. Resistors usually just burn up due to excess heat and transistors overheat and can pop, too - depending on the package they are in.
Good luck.
Jun 13, 2010 | RCA RS2041 CD Shelf System
My Fresh Air by EcoQuest blows out black like dust/substance. So much so that around the unit and on the wall is turning black. Is this working properly?
The unit is designed to drop particulates out of the air. If you have a heavily polluted area there are more allergens/dust in the air and this might create a 'dust-shower'.
The unit charges particles negatively so the particles bond with positively charged particles. Then the particles drop out of the air or stick to a nearby object. This could leave some black stuff on the wall. You can easily wipe this off, most of this is grime/dust.
Dutch
Apr 24, 2009 | Ecoquest Fresh Air Living Air Purifier
Black smoke
Change your air filter and clean the blow by tube that crosses the heads and connects to the back side of the air filter. If the tube or the air filter is clogged, then the oil that the blow by removes is going back into the cylinders, causing the black smoke. Also keep in mind that a Harley will blow a little black smoke upon starting as it ages, it's normal.
Jul 26, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Kenmore ac blowing black peices all over room.
that is foam insulation around the seal of the evaparator box pull the unit from the wall remove the cover to get to it and clean or replace it
May 10, 2008 | Kenmore 70088 Air Conditioner
Kenmore 72055 Air Conditioner Logo
277 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
