Question about D-Link DIR-615 Wireless Router
Cant get it off standby it showing a green signal bar but its red on standby
    Sergeant:
  • 464 Answers
You need to reset this wireless router. In the back theirs a small pin hole in which you insert a paperclip tip and hold in for 7-8 seconds. all lights will flash in front then you unplug the power cable from the bck then plug it back and now it reset it like it came out the box. you will have to pop in the disk or go to the d link website for instructions how to set it up.
Posted on May 29, 2010
Monitor standby won't stay on /pioneer 424mv
What is the source of the TV signal? I know many monitors have a "power-saving mode" that returns the unit to standby if there is no signal coming in.
Check that the signal cables are working (try swapping cables). Make sure the source is on before turning on the TV. Press the Input button to select a different source. Make sure that the source signal is not refreshing (or synching) at a rate that is incompatible with the TV. (If your source is a PC that was previously connected to a CRT monitor, the refresh rate should be reset to 60 Hz before connecting the computer the the Pioneer 424MV.)
I hope this helps.
(Pioneer TVs usually give a blink code if there is a hardware problem that prevents it from turning on.)
Mar 17, 2013 | Pioneer Televison & Video
Is there a on of switch and is the green or red light to be on
There is no main AC power switch on the BU series; it's in standby mode whenever it's plugged in.
When playing music normal LED color should be green. After no signal for 10 minutes or so it will turn back to Red (Standby)
Nov 23, 2010 | Infinity BU-120 Subwoofer
AR SW-30 subwoofer doesn't switch to standby mode when off
Disconnect its input cable to see if a true lack of signal lets it go to sleep. If not, it has a bug. Otherwise, you probably have some sort of signal present on the sub cable.
Jan 17, 2010 | Audio Players & Recorders
My HTC TYTN11 shows red green white etc colors when switched on
the tricolor screen means your device is on bootloader mode.
this mode is for reflashing your device OS.
if you entered this mode accidentally, you might try to release your device's camera button. Since the factory setting to enter bootloader is reset button+camera button from standby mode.
try to get battery out and release the camera button. many times happens that this button get stuck inside, because it's not a button you use many time and it get fully of dust.
Aug 29, 2009 | HTC TyTN II Smartphone
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Infinity tss-1100 sub problem
hey buddy, I have the same system, and although I haven't experienced it on this one, I had the Harman Kardon equivalent to the TSS-750, and the sub did this same thing. It was a loose RCA connection, and, as I was well outside of warranty, I took the amp out of the back and just re-soldered the connection myself. It now functions flawlessly for my bedroom setup. I hope you get it all worked out on your system! I can't imagine using this awesome system without its deep notes!
Jan 07, 2009 | Infinity TSS-1100 System
Eurovox Max 2008 wont turn off standby
Have you unplugged it from the wall?....if you have than I suggest that you install new software on it.
go to www.bigmaq.co.uk and download the tool bar, than go to files and fixex select your eurovox from the list and download software and install it onto your box.
Regards
Dec 08, 2008 | Computers & Internet
Dont know how to turn it on
Just plug it in to an outlet. The lights on the front should be red (or standby mode). When it gets a good sound signal, it turns green (that's when it's on). It does not have a power switch.
Jul 10, 2008 | JBL PB10 Subwoofer
D-Link DIR-615 Wireless Router Logo
260 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
